TLR TEN-SCTE 2.0 Kit Thread
#1306
Tech Prophet
MIP servo tape is awesome. Make sure both surfaces are clean and the chassis has a nice flat spot to get a good bond.
The ESC was put here through a lot of testing this was found to be the best location for weight. Yes the motor and sensor wires are long but it is worth it for the handling benefits.
#1307
#1309
I run 3M tape on my E-Buggy and it has been rock solid. I even took it to a Monster Jam event and was launching it 30+ feet in the air and it never let loose. I do run 2 layers to cushion it slightly. I lightly sand the bottom of the case and the chassis which will give the tape a super strong bond. Also, contacted TLR support for the replacement lower shock caps. I was wondering why mine were so hard to install. Apparently they have an issue and are issuing replacements.
#1311
Not really that bad. I am going to bolt up my shocks from my original SCTE and go take it out for a run. Support was great. They are shipping them out to me asap.
#1312
I had my ESC mounted on a gel pack in my old truck. I put the old bolink double sided tape down then the gel pack then then more tape and finally the ESC. I was ok to start with but when loose dirt got to settle at the bottom it would start to come loose. This time I am going to try to use a little shoe goo then the gel pack then more shoe goo then the ESC. I hope it works. For the RX I will just use some bolink double sided tape.
So what about servos and an external BEC do you guys use. I'm still not sure. I want to place my order today.
Anyone.....
Anyone.....
#1313
I am running a Hitec HS7940TH servo in mine. It is the same servo that I run in my ebuggy. I don't run a capacitor on it and haven't had any issues with this setup in the past.
#1314
I understand there's not a receiver box, is there any that'll fit where you mount it behind the servo???
#1315
I am actually thinking about making a small bracket to mount it off the side of the servo. Small piece of lexan should do the trick.
#1316
http://www.ebay.com/itm/3M-VHB-4941-...a547b8&vxp=mtr
#1317
Anyone.....
Anyone.....
Savox 1258TG
Novak Activ8
Novak 550 4.5 or Schuur 4300 (going to test it out)
Spektrum 3100
Mylaps Transponder
#1318
#1319
Will do, about to head to the LHS to pick up a few little pieces of lexan they have laying around to get it taken care of.
#1320
