Like Tree3Likes
Xray T1
Old 06-06-2004, 06:09 PM
  #7261
Hodapp's Avatar
RBLove - Cant say for sure right now. I would like to but carpet requires a lot of preparation and there really is no place to practice in So Cal. Never know what the future holds. Thanks for the props dude.
Hodapp is offline
Old 06-06-2004, 06:12 PM
  #7262
rayhuang's Avatar
Greg-see ya the week before the US Indoor Champs at the Gate!! All you'll need is a week on the Ozite. I'll give ya the hot-set-up for the Xray when you arrive!!! yes I am kidding!!!
rayhuang is offline
Old 06-06-2004, 06:21 PM
  #7263
SalvadoriRacing's Avatar
Default HELP ME HODAPP!
Hello Greg,
can you help me on gearing my 19T motor powered XRAY????
And what battery position do you usually run???????
thanxx!
SalvadoriRacing is offline
Old 06-06-2004, 06:29 PM
  #7264
Hodapp's Avatar
SalvadoriRacing - What kind of track are you running on. Tight, open, hooked up, loose etc.
Hodapp is offline
Old 06-06-2004, 06:44 PM
  #7265
Default Ouch
Neil,
I am using a JR RS300 With a JR XR3 Reciever and a Novak Dually ESC. When I went into the hobby shop I said "you guys ever have any glitching problems on the track?" Thier reply was oh yeah in turn two the fence runs to close to the track.
Thanks for your interest
T-Bag-R is offline
Old 06-06-2004, 06:52 PM
  #7266
HODAPP,
Here is the track layout, the straight is 60meter.....
http://www.aarcdoabc.com.br/images/pista.gif
I ran today, I tried a final ratio of 5.7, my car (19t motor) is about 1 second slower than modifieds.....
I tried the battery position that josh cyrul uses, but was the first time I run my XRAY, i don't know how the car will react with other batt positions....
Old 06-06-2004, 06:53 PM
  #7267
howard hudson's Avatar
Default maden run
well ran the new car today and it handled fantastic. Ran a spool so it pushed a little. will try a diff next time otherwise the car runs real smooth. I set up the car with gregs standard set up.
howard hudson is offline
Old 06-06-2004, 07:57 PM
  #7268
evaa's Avatar
Default Re: Spur Gears
Originally posted by psbarger
Hey guys, I'm wondering what aftermarket spur gears work with my FK? I had some Robinson racing ones sitting around but the holes don't line up with the layshaft correctly. Do Kimbrough work? What other brands? I'd like to stay 48 pitch simply so because all my other cars are 48 and I've got tons of pinions....
try the speedmind spurs. im currently using their 90 teeth spur, all i had to do was widen the middle hole a bit with an exacto knife coz it was quite a tight fit. i also dont like the stock spur coz of the flex. the speedmind spur is stiffer than the stock ones.
evaa is offline
Old 06-06-2004, 08:05 PM
  #7269
Team EAM
Trader Rating: 79 (100%+)
PRS or www.precisionracingsystems.com is making Touring car spurs now in sizes up to 132 teeth. Perfect for the Xray so you can get the motor low in the car. Machined and perfectly round and light. Yes I am sponsored by them but I would still run them if I wasnt. Quite a few factory drivers are now running the spurs and pinions as well.
EA
EAMotorsports is offline
Old 06-06-2004, 08:15 PM
  #7270
Default which trans ratio
I was told the factory fk kit has a ratio of 1.77 and is the best for carpet. He also told me for asphalt I should be running the 2.125 gears any one care to give me some input on this
Old 06-06-2004, 08:17 PM
  #7271
Default Re: which trans ratio
No, run 1.77 everywhere.
True R/C Racing is offline
Old 06-06-2004, 08:19 PM
  #7272
Team EAM
I would run the low ratio set everywhere...the ones with the factory kit. It seems to free the drive train up quite a bit. Ive run it everywhere like that...But Hodapp or one of the other guys might be better suited to answer the exact differences.
EA
Old 06-06-2004, 08:30 PM
  #7273
Default thanks
so with a 19t what kinda finals should work good with this car I tryed the REEDY (513) quad ran it around 5.7 to 6.3 no punch then tryed the camillion (trinity) up and down the scale still no punch. am I doing something wrong?????????
Old 06-06-2004, 09:27 PM
  #7274
Neil Rabara's Avatar
From the looks of it, you geared the Reedy quad incorrectly. I don't know much about the Trinity.
Neil Rabara is offline
Old 06-07-2004, 01:44 AM
  #7275
evaa's Avatar
Default Re: thanks
yep, looks like you fried ur 19t motor with that high a gear ratio, try running it in the 6.5 to 6.7s, just my thought anyway.
well, while were at it, what is the difference between a 1.77 trans ratio as opposed to the 2.125 of the FOC? am a bit confused if i need to change to the 1.77. i run on a fairly technical track, asphalt, med grip.
tanx for ur inputs guys.
evaa is offline
