Kyosho VoneR Thread
#4711
hey clammasive, take the v one rr out for a race/bash yet?
or r u still too busy wit school?
#4712
Re: newbie question
Originally posted by patelladragger
I'm trying to take apart an engine for the first time. Can anyone give me any tips on how to get the rod off crank so I can get the piston/sleeve out? I'm scared to pull on anything too hard. thx
#4713
AMGRacer:
I see in your signature line that you have a Richie RTU. Have you opened it up for a look at the mods?
#4714
Originally posted by RC
AMGRacer:
AMGRacer:
#4715
AMGRacer:
#4717
Originally posted by sparksy
Is the pope a catholic?
Does a bear shit in the woods?
Do fat chicks sweat in summer?
#4718
Gearing...
Hi All...
I am currently running stock gearing, 16/20 48/44.
If I want to increase the low-end torque, can i only change the 1st pinion gear from 16T drop to 15T? is this ok?
Must i change the 1st spur to 47T also?
Kindly advise...cheers
#4719
Originally posted by deeno_x
Where to get those Richie TRU? Any info?
For now, we just have to be contented with the JP modified, M-Speed, MS tuned or Rody tuned engines...
#4720
don't forget about j=tech, he's right there.
On these M-speed? Anybody know anything about them? I know they're incredibly expensive - I saw on OS 01 go for over 400 dollars on ebay. What's the scoop on these?
#4721
Re: Gearing...
Originally posted by RClover
Hi All...
Hi All...
Only problem I can see is that a 5 tooth spread may drop you out of your powerband on the 2nd gear shift depending on engine type.
#4722
I have never seen a M-Speed going but I have heard that they are nothing special over any other modified engine. Just really expensive.
#4723
hey guys, i have a problem, i cant get my overall width to be 200mm and under, its over if i use 30mm rear tyres. if i just tighten the pivotballs and screw them in more, when i compress the chassis, it doesnt go down all the way due to the fact that there isnt enough room for the dogbone to move. any ideas?
#4724
Make sure you are using the short dog bones for the rear, they are identifiable by a raised ring in the middle of the shaft.
#4725
ok, thxs
