Old 10-16-2002, 04:02 PM   #4711
asd
Send a message via ICQ to asd
hey clammasive, take the v one rr out for a race/bash yet?
or r u still too busy wit school?
asd is offline   Reply With Quote
Old 10-16-2002, 04:27 PM   #4712
AMGRacer's Avatar
Default Re: newbie question
Originally posted by patelladragger
I'm trying to take apart an engine for the first time. Can anyone give me any tips on how to get the rod off crank so I can get the piston/sleeve out? I'm scared to pull on anything too hard. thx
On most of my engines I persuade the sleeve with a piece of bamboo. Anything wood and softish is fine, just push hard enuff and it should pop, then you can pull from the top. The rod will not come off with the sleeve in place.
AMGRacer is offline   Reply With Quote
Old 10-16-2002, 04:35 PM   #4713
RC
AMGRacer:
I see in your signature line that you have a Richie RTU. Have you opened it up for a look at the mods?
RC is offline   Reply With Quote
Old 10-16-2002, 05:48 PM   #4714
AMGRacer's Avatar
Originally posted by RC
AMGRacer:
Nope never
Old 10-17-2002, 04:44 AM   #4715
AMGRacer:
Where to get those Richie TRU? Any info?
deeno_x is offline   Reply With Quote
Old 10-17-2002, 04:51 AM   #4716
sparksy's Avatar
Trader Rating: 14 (94%+)
AMGRacer:
Is the pope a catholic?
Does a bear shit in the woods?
Do fat chicks sweat in summer?
sparksy is offline   Reply With Quote
Old 10-17-2002, 08:56 AM   #4717
Manticore's Avatar
R/C Tech Charter Subscriber
AMGracer has the answers !
Manticore is offline   Reply With Quote
Old 10-17-2002, 12:07 PM   #4718
RClover's Avatar
Default Gearing...
Hi All...
I am currently running stock gearing, 16/20 48/44.
If I want to increase the low-end torque, can i only change the 1st pinion gear from 16T drop to 15T? is this ok?
Must i change the 1st spur to 47T also?
Kindly advise...cheers
RClover is offline   Reply With Quote
Old 10-17-2002, 12:15 PM   #4719
InitialD's Avatar
No more in production... At least for now. Mr. Dennis Ritchey has stopped making it for the moment.
For now, we just have to be contented with the JP modified, M-Speed, MS tuned or Rody tuned engines...
Old 10-17-2002, 12:56 PM   #4720
patelladragger's Avatar
Send a message via AIM to patelladragger
don't forget about j=tech, he's right there.
On these M-speed? Anybody know anything about them? I know they're incredibly expensive - I saw on OS 01 go for over 400 dollars on ebay. What's the scoop on these?
patelladragger is offline   Reply With Quote
Old 10-17-2002, 04:36 PM   #4721
AMGRacer's Avatar
Default Re: Gearing...
Originally posted by RClover
Hi All...
Yes you can freely change the spurs. Kyosho has kindly made them all the same size regardless of number of teeth so your mesh should also remain static.
Only problem I can see is that a 5 tooth spread may drop you out of your powerband on the 2nd gear shift depending on engine type.
Old 10-17-2002, 04:42 PM   #4722
AMGRacer's Avatar
Problem with j-tech was that he ignored repeated emails from me requesting info. Perhaps he does not want to send overseas?
I have never seen a M-Speed going but I have heard that they are nothing special over any other modified engine. Just really expensive.
Old 10-17-2002, 06:08 PM   #4723
asd
hey guys, i have a problem, i cant get my overall width to be 200mm and under, its over if i use 30mm rear tyres. if i just tighten the pivotballs and screw them in more, when i compress the chassis, it doesnt go down all the way due to the fact that there isnt enough room for the dogbone to move. any ideas?
Old 10-17-2002, 06:10 PM   #4724
RC
Make sure you are using the short dog bones for the rear, they are identifiable by a raised ring in the middle of the shaft.
Old 10-17-2002, 06:11 PM   #4725
asd
ok, thxs
Kyosho VoneR Roller $120 Tag R/C Items: For Sale/Trade 4 08-06-2003 07:22 PM
kyosho VoneR w/ nova, pipe $200 Tag R/C Items: For Sale/Trade 9 07-25-2003 03:09 AM
Kyosho VoneR Macky R/C Items: For Sale/Trade 6 07-31-2002 09:04 AM
Brand new Kyosho VoneR kit $230 Tag R/C Items: For Sale/Trade 0 10-22-2001 02:12 PM
NIB Kyosho VoneR $250 Tag R/C Items: For Sale/Trade 4 10-21-2001 06:39 PM
