Team Durango DEST210R thread
#1096
Those are Durango springs. Here's the complete chart:
http://www.team-durango.com/blog/201...spring-charts/
What sort of track are you running on? I run on carpet so my shock setups are probably going to be a lot different than those that run on dirt.
#1097
Online store
Hi! Will you recommend an Asian (HK,Chine,etc.) store that caries TD parts,please!
Thanks!
Thanks!
#1099
I am going to get my Dest back up running again. I am installing a gear diff this time, with a 10.5 motor, and see how that works out. I will be using the plastic diff gears in it(moulded.) We don't have a class for it yet, but that is always subject to change.
#1100
hey guys I just bought my first Durango...looking for a recommendation on a good setup sheet to start with for MM4 on a medium/high bite clay indoor track. Thanks
#1101
can anyone tell me what the metal part equivalent for the kit RF suspension mounting, specifically #330341-3, the one that gives three degrees toe in and anti squat. My chassis is the old dest210r one. I think pre type B. Anything from Durango, RDR or whatever will be great. Thank you.
#1102
http://www.exotekracing.com/dex210-r...ith-shims-lrc/
or
http://www.team-durango.com/part-inf...artNo=TD330565
#1103
Kremzeek: Thank you!
#1104
chassis
Hi there! Does the DESC and DEST has the same chassis?
#1105
#1108
Re: !
Tanks for reply! The reason I'm asking is Phat Bodies chassis hugging overbody for the Durango DESC210.
Do you think it will fit on DEST chassis?
#1109
I have built and rebuilt at least four different transmissions both mid and rear mount and have always had a tight spot when spinning the gears by hand. Has anyone had this issue and did you find a solution for it. I looked at all the gears and transmission cases and can't find anything.
#1110
Re: ?
Over tight diff case,perhaps.
