Team Losi JRXS Type-R >
Like Tree52Likes
Old 07-06-2009, 02:38 AM
  #9796
Pablo Diablo's Avatar
Originally Posted by bertran
THE LOSI IS OUTDATED! GET AN "AWESOMATIX" WHEN IT COMES OUT!!!!!!
Why would anyone come onto the Type R thread and post something silly like that. If anything shaft drive cars are out of date. No respected manufacturer has used that design in a top level racing chassis for a long time.
Pablo Diablo is offline
Old 07-06-2009, 05:58 AM
  #9797
Originally Posted by Chill_Will
Ripnroar - I have a 102 spur you can try. You will need to get a 53(3.52), 52, 51 just in case your motor gets too hot.
what pitch is that Chill, a 64 or a 48, thanks.
ripnroar is offline
Old 07-06-2009, 06:15 AM
  #9798
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
dont worry he is gone for now
Marcos.J is offline
Old 07-06-2009, 07:00 AM
  #9799
Chill_Will's Avatar
Trader Rating: 33 (100%+)
64p
Chill_Will is offline
Old 07-06-2009, 08:34 AM
  #9800
jrxs-r's Avatar
Trader Rating: 11 (100%+)
Originally Posted by Chris08527
where do you guys run your front and rear roll centers on rubber tire asphault???
It will depend a lot on traction available. At my local tracks i run Front - Low +1.3mm, and Rear - Low settings. Its also largely dependant on the spring rates that you use too... just to confuse things a little.
jrxs-r is offline
Old 07-06-2009, 09:34 AM
  #9801
John Tag's Avatar
Trader Rating: 42 (100%+)
Chris ..
My car is ultra stable on all track I run on with High roll centers f&r.. .040 bars F&R...stock 56 pistons and 15 lb springs 40/45 oil. Spool OD41T front ....Diff rear High location....5/b rear camber.stock shock location. 1* rear block.
John Tag is offline
Old 07-06-2009, 08:15 PM
  #9802
espresso1967's Avatar
Trader Rating: 18 (100%+)
Needing help. Rebuilding one losi 10mm shock for my pan car as that it what is uses. The question is, anyone using the optional double o-ring option and if so does it make any difference vs single o-ring?
espresso1967 is offline
Old 07-07-2009, 03:02 PM
  #9803
tim fry's Avatar
anyone know if the flyingfox layshafts are back in stock yet?
tim fry is offline
Old 07-07-2009, 03:05 PM
  #9804
sportpak's Avatar
Trader Rating: 26 (100%+)
I use the twin oring setup. The shock isn't quite as free, but it seems to seal better over a given amount of time.
Ben
sportpak is offline
Old 07-07-2009, 03:32 PM
  #9805
Trader Rating: 50 (100%+)
Originally Posted by John Tag
Chris ..
what tires are you running with that set up John?
Jaz406 is offline
Old 07-07-2009, 03:39 PM
  #9806
YmeBP's Avatar
Trader Rating: 32 (100%+)
As a matter of fact they are you must be a mind reader.
They are currently back in stock and I'm filling back orders (some went out today already).
My shipping time to the UK is via USPS Global Priority, which should take about 6 to 10 days.
YmeBP is offline
  #9807
John Tag's Avatar
Sorex 36's..No heat or sauce...
John Tag is offline
Old 07-08-2009, 12:46 AM
  #9808
Ben
Yes my shocks lose rebound so I am looking to do this soon. As far as a bit more friction is concerned I all ready run 57 pistons to increase dampening/pack as the losi will ALWAYS have rapid direction change so there is little need to consider that in you dampening setup. A little heavier will promote more mid corner performance so double o-rings will not hamper performance.
As for rubber rollcenters I run full low all round. This has allowed me to match the lap speed of our countries fastest driver (B final at last worlds). For me rubber is simple.. full low and tune from there as you can reduce steering easy if you have too much grip but adding more if you need it is time consuming when you need to play with rollcenters for more grip. I have tried diffs low and high and feel no difference but high has the advantage of keeping the belts a pulleys away from the crap on the track so I now run high all round.
Dragonfire is offline
Old 07-08-2009, 07:18 AM
  #9809
YmeBP's Avatar
I've seen both high and low roll centers used at the same track effectively, leading me to believe it's about driving style and rest of car setup, but I'd love to understand what the difference in roll centers does to the Type-R vs the traditional TC.
This is an awesome explanation of Roll center: http://www.rc-truckncar-tuning.com/roll-center.html
a short excerpt:
Roll center is the point on your chassis, both front and rear, the point your rc vehicle pivots on in a corner. In most cases the roll center will be different on the front and rear, since we hardly ever have the front and rear suspensions setup the same. In a corner centrifugal force causes your rc car or truck to lean into the corner. The point at which your front suspension pivots on is your front roll point and the same holds true for the rear suspension.
So my question is how does this "lean" affect the Type-R specifically, does low roll center promote lean, or does high roll center promote lean?
I've been talking about roll in the corners quite a bit with Scooby and how to get the car to roll without dumping over in sweepers, yet maintain the snappy-ness in the chicanes.
YmeBP is offline
Old 07-08-2009, 07:33 AM
  #9810
4wheeldrift's Avatar
Its the distance between the center of gravity and the roll center. The larger the distance the more leverage = more lean. Lower roll center is going to be a greater distance from the CG. Good example would be off road cars. High CG, low RC. Motorcycles are the opposite. Low CG and very high RC, thats why they lean into a corner.
I use this software http://www.rctech.net/forum/electric...alculator.html
For me having roll centers within a mm front to rear seams to work out the best for me.
4wheeldrift is offline
