Team Orion Advantage Charger
#316
Originally Posted by EVOtech
I decided our 7A linear PSU was too heavy to keep lugging around and so bought a 20A switch-mode unit, which is less than half the weight.
When the Advantage is step-charging, it manages steps 1 and 2 OK, but in the transition to step 3 trips the swich-mode out. I'm using 7A/0.5A/6A
For this to happen, the current has to be more than 25A. Might this indicate a first-batch problem?
It seems to behave OK on the linear supply.
Your first step is set to 7A and it seem to work fine, because the step 1 maybe a linear charging for 10~20 sec. But as soon as the step 3 kicking in to 6A from .5A your psu may not be able to handle the “in-rush” current. The “in-rush could spiked up past the tripping point of your psu. The in-rush current could be more than 25A for a milli sec or less, but because your psu’s protective circuit is so sensitive. That’s why it kept tripping.
Just my .02
#317
#318
well-I really think this charger does a great job-but I am flustered by its navigation. Yeah-I know what a grey matter challenged person that makes me and I dont care
I have one quick navigation question!! What are the steps to get back to the "time" screen? I dont seem to be able to ever get there except by unplugging and plugging back into the PS.
#320
#321
Originally Posted by Chris Brown
rayhuang- go to the battery management screen and scroll through that and it will take you to the time.
kewdawg-yeah-I feel so stupid at thetrack hitting the buttons 500 times (beep-beep-bep-beep-beepbeep-beep-beep.....) then I stand there, mouth hangin open staring at the charger for 20 seconds-and my buddy pitted next to me asked "what the hell are you doing??" And i just say-trying to find where I stored my 4-cell charge profile Its pathetic.....
#322
It does taking some getting used to. I always screw up and don't push the start button for charge twice when it asks to discharge first or to set the time before start. I really do like the charger though, very nice unit once you figure it out. Oh, and I turned the beeping off, it was annoying. Also, just a friendly hint, don't change the language to german or japanese if you don't know the language, it will be difficult to get it back to english.
#323
That did the trick-thanks!!
#324
Hey everybody,
I just bought the Team Orion Advantage charger a wanted to know what power supplies you are using with it? I was looking 13.8vdc 15amp radio shack unit, would this be suitable for it? This is my first DC only charger and need some assistance on what a good and compact power supply to use would be.
Thanks,
Daniel
Thanks,
Daniel
#325
Originally Posted by vulso
Hey everybody,
Thanks,
Daniel
Thanks,
Daniel
#326
This is the best and cheapest Power supply that I have found. I have two and still payed less than most people on just one...
Hope this helps....
Also Tre's Leonard makes killer face plates for it also....email him through the link in my signature....
http://www.buyreliant.com/psupplies/psv200.htm
-Shookie <><
Hope this helps....
-Shookie <><
Hey everybody,
Thanks,
Daniel
Thanks,
Daniel
#327
I have the 25 amp Radio shack unit and it's a great power supply. I currently run two Advantage chargers, my fan for my integy 030 tray and my Yokomo motor system off it, sometimes all at once and the thing never even flinches. I saw that the one Shookie said and it looks nice too, but I just know that the Radio Shack one is awessome. Also, if there is a problem with it, there are a million Radio Shacks around.
#328
Maybe someone has the same problem:
I was unable to use the delay with the step charge mode, it seems to impossible???
It works fine with the normal charge mode.
Any help will be appreciate. Actually I bought this charger for the step charge mode and the delay mode.
Bye
Bye
#329
Bye
Bye
#330
