Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#1846
How to remove grease of my gearbox on the lazer zx6
What/how would I remove grease from my gear box easy way.
#1848
Hello everyone, I present to you my project to add a slipper/differential to the ZX6.
First the slipper/differential, it is made by using some part of the durango DEX410v5 :
Integration in the ZX6 :
The final render :
Lets make it real
3D printed part :
Slipper assembly :
Differential assembly :
Note instead of Durango slipper/differential, we can change diff oil without need of disassemble the slipper clutch
The slipper/differential full assembled :
Everything is ready for the test
Note the steering plate made for easier bump steer adjustement (and it's stronger here than on the hub side)
The final render :
Lets make it real
3D printed part :
Slipper assembly :
#1849
The final render :
Lets make it real
3D printed part :
Slipper assembly :
The final render :
Lets make it real
3D printed part :
Slipper assembly :
That's impressive! Very nice. How does it preform? What kind of track do you run on?
#1850
I will try this afternoon on my local track (grass, turf and some dirt)
#1851
First run done :-)
The car can maintain a lot of speed while turning, I need a litle more setup, because she is too agressive in mid turn
#1852
For all you carpet guys I have a setup issue. I'm running the Tebo world setup on carpet and the rear end seems to jump up going over a couple a little jumps any ideas how to fix this?
#1855
I'm in holidays with my family, I will give you t dxf for the carbon part and the link printed it on shapeways.
I need to correct the assembly manual to make everything fine ;-)
#1858
Anyone try mounting the rear shocks to the rear of the car behind the tower and arms, if so can you post a pic?
#1859
I'm swapping out my chassis to a hd chassis on my zx6. In the bag they give you 2 center drive bones with rubber o rings. Tried to use the bones they gave but they are to short. Has anyone else ran into this issue. Thanks.
