CRC's New Generation-X.... Your Thoughts?
#931
Originally Posted by arr see car
Where is the best place to get the gen-x from who ships overseas.
Can't find anyone in Australia who sells them.
There's a coulpe of us who want it
#932
Originally Posted by catcars
A little late but Odpurple, your car looks fantastic. The wiring detail is particularly trick. I saved the images for futher use. Thanks!
#933
anyone got a good asphalt setup for mod?
#934
#935
asphalt....
max caster w/5 deg. blocks and stock frnt spring...
white side springs with red shock spring w/35wt...
medium tube lube, batts forward...
full size pro-cuts....majenta rear, purple front...
4-5mm ride hight...
4-5mm ride hight...
#936
Jack, Did you guys get your new carpet and if so what is the spring and summer schedule???
Roger T
Roger T
#937
Originally Posted by STARSCREAM
asphalt....
4-5mm ride hight...
4-5mm ride hight...
#938
Carpet...
.55 front spring with purple trinity lube....10deg. block, full caster...
White side springs...35wt with copper shk spring..Mugen 30000 in the tubes(thx smyka)...
Battery forward...1.85 rear tire...1.75 front...
ProCut tire will vary depending on grip...but I like Purple frt and Magenta R usually...
3.5mm off the rug...
#939
Carpet...
#940
I run pretty much the same setup all the time but I mostly run mod...
#941
i see
well since were on the topic of setup heres mine most of the time.
50 front springs with blue cap lube
10deg block, full caster
white side springs 25 oil copper spring,blue cap lube in tubs (some times 20000 to try)
battery forward, 44-46 purple-pink (some times magenta)
.5 droop 3.5 hight,
rpm side links,they keep the car stable,dont ask me how or why they just make the car run good.
slapmaster trust bearing when i dont want to kill the outer bearing but will give mid corner push.but it is very nice.
.5 droop 3.5 hight,
#942
ride height adj
Hey Guys,
Has anyone had problems with the IRS or even the stock ride height adjusters being extreemly loose in the right rear bulkhead?
#945
Roger T
Roger T
I will post the Spring/Summer Schedule ASAP on the web site. Did you fine another GenX? I have someone at the track looking for a 12th scale (Jenzo). Hope to see you soon. I have been running PanCars the last few weeks. It's still alot of fun. Kevin Kliber set a new track record Sunday on the Oval. He was Smokin'. Check out our Forum on the track website.
