Old 03-24-2007, 10:25 AM   #931
Originally Posted by arr see car
Where is the best place to get the gen-x from who ships overseas.
Can't find anyone in Australia who sells them.
There's a coulpe of us who want it
Yeah, Like Wally said. Order direct from CRC . Just make sure you order some extra parts in advance.
jackh is offline   Reply With Quote
Old 03-24-2007, 11:15 PM   #932
odpurple's Avatar
Originally Posted by catcars
A little late but Odpurple, your car looks fantastic. The wiring detail is particularly trick. I saved the images for futher use. Thanks!
You're welcome, good luck with the build
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 03-26-2007, 10:18 AM   #933
Trader Rating: 68 (100%+)
Send a message via AIM to joey
anyone got a good asphalt setup for mod?
=Joe Wright=
joey is offline   Reply With Quote
Old 03-26-2007, 03:10 PM   #934
wallyedmonds's Avatar
i'd like to know this too for summer.
wallyedmonds is offline   Reply With Quote
Old 03-26-2007, 07:03 PM   #935
STARSCREAM's Avatar
asphalt....
max caster w/5 deg. blocks and stock frnt spring...
white side springs with red shock spring w/35wt...
medium tube lube, batts forward...
full size pro-cuts....majenta rear, purple front...
4-5mm ride hight...
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 03-26-2007, 07:13 PM   #936
rogtsaamokin's Avatar
Jack, Did you guys get your new carpet and if so what is the spring and summer schedule???
Roger T
rogtsaamokin is offline   Reply With Quote
Old 03-26-2007, 10:31 PM   #937
Originally Posted by STARSCREAM
asphalt....
4-5mm ride hight...
and whats your carpet setup.
Old 03-26-2007, 11:00 PM   #938
STARSCREAM's Avatar
Carpet...
.55 front spring with purple trinity lube....10deg. block, full caster...
White side springs...35wt with copper shk spring..Mugen 30000 in the tubes(thx smyka)...
Battery forward...1.85 rear tire...1.75 front...
ProCut tire will vary depending on grip...but I like Purple frt and Magenta R usually...
3.5mm off the rug...
Sean Maybell
Old 03-26-2007, 11:04 PM   #939
Carpet...
this is for mod or 19t
Old 03-26-2007, 11:06 PM   #940
STARSCREAM's Avatar
I run pretty much the same setup all the time but I mostly run mod...
Sean Maybell
Old 03-26-2007, 11:20 PM   #941
i see
well since were on the topic of setup heres mine most of the time.
50 front springs with blue cap lube
10deg block, full caster
white side springs 25 oil copper spring,blue cap lube in tubs (some times 20000 to try)
battery forward, 44-46 purple-pink (some times magenta)
.5 droop 3.5 hight,
rpm side links,they keep the car stable,dont ask me how or why they just make the car run good.
slapmaster trust bearing when i dont want to kill the outer bearing but will give mid corner push.but it is very nice.
Old 03-27-2007, 08:20 AM   #942
Default ride height adj
Hey Guys,
Has anyone had problems with the IRS or even the stock ride height adjusters being extreemly loose in the right rear bulkhead?
march to my own is offline   Reply With Quote
Old 03-27-2007, 09:02 AM   #943
anyone?
Old 03-27-2007, 09:48 AM   #944
Trader Rating: 21 (100%+)
You need to take a side cutters and give the edge a slight squeeze and make a dimple. Check out the tech section on the CRC site and go down to build tips.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 03-27-2007, 11:49 AM   #945
Roger T
rogtsaamokin, yes the carpet is in and the guys are lovin' it.
I will post the Spring/Summer Schedule ASAP on the web site. Did you fine another GenX? I have someone at the track looking for a 12th scale (Jenzo). Hope to see you soon. I have been running PanCars the last few weeks. It's still alot of fun. Kevin Kliber set a new track record Sunday on the Oval. He was Smokin'. Check out our Forum on the track website.
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
