Tamiya TRF415
I always thought it was like what rtypec said. Shocks angles mainly affect the feel of the car from what I understand, rather then altering levels of steering and stiffness. Sure it does adjust that, but its more to do with the feel of the car for your driving style.... I thought anyways.
Originally Posted by bender
According to that link you posted you've got it backwards
"The formula tell us that the closer the bottoms of the shocks are mounted to the middle of the chassis, the softer the wheel rate will be."
well, after 8 months off racing and selling all my gear, i have made a return with a Tamiya MSX. Only problem now is it is christmas and the damn track is closed
haha, i've got the same problem. The car has been built for more than 1 week but i have nowhere to run it
Guess I need to sit down and get it sorted in my head
Cheers
Ed
After buying so many spare and option parts for 415 series (the latest being the MSX Conv kit), I've decided to rebuild another 415 but w/ the std arms instead. I just needed to buy several parts for the drive train & other miscellaneous parts (spacers, shims etc.). But the most major parts I needed that cost a lot of $$ was the bottom deck & TRF blue dampers, the speedo & servo - had those already.
My only problem though would be I will have 3 TRF kits (check my sig) & can't decide which one to race. The TRF414M is fully hopped up (but not set up yet for my track & don't have time to do - I only race 2 Friday's a month). Most likely down the line will have to let go (or not) of the 414M which probably cost more of money spent re to options parts than the 415.
Just wanted to share my story on our thread during the holidays. But will also like to greet everyone A FUN FILLED HOLIDAY & A RC FILLED 2006.
Later........
Originally Posted by TryHard
hmm...now I'm really confused!
Cheers
Ed
Cheers
Ed
I was just going by my off-road experience.
When you move the shocks further out on the arm (and move them further out on the tower to keep the angle the same) then that makes the suspension stiffer, as the ratio between suspension movement and shock travel is more linear.
When the shocks are moved in on the arm (closer to the inner pivot point) then the amount of suspension movement is now greater in relation to the shock travel, so in effect the shock (and therefore spring) are being compressed less over the same distance - in other words the spring is providing less resistance to the suspension movement - which makes it softer.
I'm not sure if that makes it clearer or more confusing
Anyway, I just wanted to know mainly because if hole 2 is what most people run on ashpalt with rubbers then it's easier to use that as my baseline setup and work from there
Bought another VOLAC. It was on sale for $120 Goes nice in the MSX!
I didn't put it in the car yet
Just want to say Happy Christmas to everyone on here.
Hope you have a good one.
Regards
Ed
Regards
Ed
Regards
Ed
Regards
Ed
ahh it's the christmas eve pub trip
Loveing the new licensing laws
novak body
just painted it for the novak race
Very Nice ! It looks Fast...........Your halfway there..............
Happy Holidays to all 415ers around the world.
