Like Tree164Likes
Tamiya TB Evo 6
Old 04-27-2016, 07:24 AM
  #1801
theproffesor's Avatar
Trader Rating: 66 (100%+)
So besides the motor mount, what's the difference? Will it come with the aluminum lower bulkheads?
theproffesor is offline
Old 04-28-2016, 03:13 AM
  #1802
fyrstormer's Avatar
Originally Posted by kentech
TB Evo 6 MS set for June 18 Japan release
https://kentech.wordpress.com/2016/0...icial-picture/
So basically it's a shaft-driven TRF419. That's cool, though I have to say the TA-07's serpentine-belt drive looks more intriguing to me from a technical perspective.
fyrstormer is offline
Old 04-29-2016, 11:50 AM
  #1803
robk's Avatar
Trader Rating: 22 (100%+)
exo6 with both chassis for sale
http://www.rctech.net/forum/r-c-item...m-chassis.html
robk is offline
Old 05-02-2016, 02:47 AM
  #1804
Aitutaki's Avatar
Hi Guys,
there was a LRP Challenge Race this weekend in austria on a low grip tarmac surface. i started once again with my Exo6 in a 17,5T blinky race with 4,5 FDR .
I had to chance a few things to get the car work good for me
1.) i changed from Spool to Gear Diff in the front with 1.000.000 Oil (It was a very tricky course and just a few straights.
2.) to get more grip on the rear i went to the 6th Hole for the rear dampers.
3.) I switched from pink to green kokomo Springs in the front (very hard)
4.) Front Block changed from B to C , to get 0,5 degree angle
This helped me made it to the podium.
once again, during a 12 minutes A Main, my nervs weren't the best , that i did two mistakes each run, but thats me, and still i am happy about the performance of the xo 6 in this class !!
cheers
Flo
Aitutaki is offline
Old 05-02-2016, 02:55 AM
  #1805
Aitutaki's Avatar
enclosed a Pic of the Track , the green Ford GT Car is mine
Aitutaki is offline
Old 05-02-2016, 07:22 AM
  #1806
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Do you guys spray the track for traction?
Josh-n-ya is offline
Old 05-02-2016, 07:54 AM
  #1807
Aitutaki's Avatar
It depends on the Track . Some do , some not.
In this case , this club wasn't doing anything ;-)
But it's ok , as every driver has the same conditions ..
Aitutaki is offline
Old 05-05-2016, 02:03 AM
  #1808
yeeeaaahhh the come back of tb evo
TG MAN is offline
Old 05-05-2016, 02:14 AM
  #1809
gigaplex's Avatar
This new model doesn't look all that different to the old one. I doubt it's going to make much of a difference.
gigaplex is offline
Old 05-05-2016, 06:03 AM
  #1810
From what I have read, if you run the Exotek conversion, there really isn't any difference.
Old 05-05-2016, 06:15 AM
  #1811
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Aluminum lower bulkheads
RedBullFiXX is offline
Old 05-05-2016, 06:38 AM
  #1812
Where did you see that info? I know they are making aluminum lowers, but I can't find where they are included. I did see that the upper aluminum shock mount is different. But it only appears they changed the type of screw used to mount it to the upper bulkhead.
If the new aluminum lower bulkhead is included, that would be great, but I am sure it will also be reflected in the price.
Old 05-05-2016, 12:51 PM
  #1813
Wishful thinking
Looks like they are in stock at Tamiya
http://www.tamiyausa.com/product/ite...oduct-id=84425
Old 05-05-2016, 03:23 PM
  #1814
Is there a complete listing somewhere of all the available hopups for the TB04/R chassis?
TheBen is offline
Old 05-05-2016, 05:09 PM
  #1815
Trader Rating: 28 (100%+)
Thumbs up
madjack is offline
