Tamiya TB Evo 6
#1787
http://www.rctech.net/forum/r-c-item...-m05-tt02.html
#1789
Hi Guys,
my name is Michael and I'm from Germany. Here only a few People have the EVO6, so I decided to ask you for some help.
I just started RC racing a few moths ago with an old TA04. I just bought a EVO6 to compete 21,5T in summer. I build it last weekend and I have a question that some of you could help me with.
After mounting the spur to the spur holder and the main shaft I placed it in the center bulkhead and fixed it with the 2 srews. Now I saw there is a lot of side to side movement when it is mounted so that the spur is kind ob wobbeling when I spin it. I think there are 5/10 of a milimeter space between the bearing of the spur holder and the fange of he main shaft.
I thought of placing a shim here to reduce the clearance.
Did anyone also noticed that? Is this kind of normal and I can use it like that?
I hope I explained it good enough to understand.
Best regards, Mike
Best regards, Mike
#1790
Add shims anywhere you think is appropriate. It's easy to tell if the extra movement is necessary or not. In that location, the extra movement obviously isn't necessary. However, I don't think it will cause any problems either; I have the same movement on the spur shaft in my TB04R, and it's fine because there is no sideways load placed on that shaft.
#1793
Hi Guys,
Best regards, Mike
Best regards, Mike
#1794
I got an ARC R11, so trying to get rid of the EXO6.
Here's my local fs post, I can ship it to the lower 48 for $10 more:
http://www.rctech.net/forum/14483347-post3285.html
#1796
Trader Rating: 89 (100%+)
#1797
Has anyone tried ceramic bearings in their evo6 gear cases as a way of reducing "bind" at the pinions? I'm no expert for sure but I would think a top quality bearing may handle the radial load better than the kit supplied ones. I'm hoping someone else has tried this with good results?
#1799
Hi guys
May I know what is Evo 6's default steering (in terms of degree) as I noticed that my Evo 6 steering angle seems to be a little less. Thanks.
#1800
