Getting past the wall
#31
I don't think so. And, no, I am used to much larger, open (but still technical) tracks.What was the lap in mod? 10 seconds or thereabouts? Our track is about 18s. Some of the toughest races are in 21.5 blinky. Not sure why you're talking about hairpins. I commented that there was no room to try anything on that track, there was just enough room to squeeze a car in quite a few places, so everybody had to go in line.
Hairpins force drivers to defend and increase the possibility of them making a mistake etc, or allowing you to try a different line as they are forced to defend.
There was plenty of room, but the track was so flowing that attacking was difficult.
#32
Well, I followed the advice given and took what I thought was an extreme amount of dual rate out and went full compound on the fronts. DR went from 75 to 50 and added some negative Exp. First full pack was a little trial and error, but I finally found the fastest way around the track. I cleaned recharged and went a second a lap faster. Most of that speed was traction coming up, but it now felt more natural. 3rd pack and I was on the track keeping up and passing one of the faster racers and had a blast. By the 4th pack traction was up and fastest laps and averages on the same layout were back to the levels at the end of practice Sunday. I went out with 2 other racers, one a regular winner on and off-road. I left everything the same and for the first time I can remember, I ran within a tenth of a second of fastest lap and stayed with the other cars. I picked up that half second on average and dropped my fastest lap time the same amount. The time itself is unimportant as the key was to run with the lead pack. Done!
Thanks to all who gave an example of one simple thing to try.
#33
Thsee are are great ideas. Never used any of them but will try on the next test and tune. The way I have gotten faster is by running two classes with similar chassis. I got into mod and just drove that for a couple months now I run both and I have gotten considerably faster in stock. I am also getting faster in mod due to learning the lines with the slower class and transferring it to the faster class. You don't necessarily need to run mod and stock, any two classes that are similar will work like spec gt and 17.5 which is what I used to do as well.
#34
one thing you could try is what I did to get ready for my 1st year at Snowbirds. I normally dont run sedan 17.5 and was looking to gain every tenth I could find....my setup was basic and my driving was about the same. But In order to make a good showing I needed more. So what I did was after a lot of practicing I came to the track and watched EA and Skeen battle tick for tat to clear tenth after tenth....it was amazing what they was doing to gain those few tenth. So when I came I left my gear at home and brought pen and paper and took a ton of notes and studied them...everything from their trigger fingers to small turns of the wheel...50% watching them, 50% watching the car on the track. Collected all my note and applied as much as needed...the result?....best fastest cleanest driving Ive ever done...oh yeah 2012 Snowbird Champion in AM 17.5 and 2nd place VTA to boot...thanks to EA and Skeen and watching two Pros go at it
#35
good read
Good read as I am new to the rc onroad race format. For now I am racing a tamiya tt-02 in a tamiya based tub chassis the hobby shop has. From there I plan to build the tc4 I have as a usgt just to get my feet going. But my question is this I seem to be doing alot of spinning out in corners an such I used the traction compound on the hpi X pattern tires we can run those or the 24mm gravity. All that race this class all have same setup. So my question is on a carpet track coming In an out of the corners an losing control could it be not staying on a lil throttle or over steering.. Also what is your alls perspective on the two types of tires mentioned. As these are the only two the hobby shop allows.. Also o/p sorry to hijack your post but there was some pretty knowledgeable post this is why I asked. Thanks in advance
#36
There is an optimal slip angle for maximum lateral force, and going past that will reduce lateral force. Those of you guys who have 45 degrees of steering angle might be leaving a lot of front grip on the table.
I normally limit my front steering to 12-13 degrees each way. Guys who have driven my cars have a hard time at first because it doesn't have a lot of steering angle and they have to plan their lines better.
Mark
#37
I've experimented in practice with slowing down the steering speed on my radio and my lap times improved...up to a point. Then they started to slow down again. Very interesting....
Mark
#38
#39
Ivan
#42
currently I am using the friction shocks I used some vaterra oil filled an this is what I noticed I swapped them for the stock friction shocks.. should I place the vaterra ones back on
#43
One other thing to consider is torque steer in your TT02. I currently run an almost bone stock TT01 with almost no adjustability and other than the torque steer in our USGT type class, it's pretty competitive. I just can't punch the throttle out of the apex but have to nicely full throttle it or my car will over steer like crazy. Actually really good class for me to work on throttle and brake control. Or other option is to get an Awesomatix, which has no torque steer.
Ivan
Ivan
#44
So when I get out of a turn and punch the throttle, if I'm going right, my car will oversteer more so than on the left. I agree there needs more weight transfer but droop is near impossible to set on the TT01.
Smooth throttle control is really my point.
Ivan
#45
Given the car is a TT01 I think it can be torque steer and a million other things. I have seen people race TT01 successfully on carpet in 21.5 with no handling issues, so it can be addressed, but it's a pain in the butt.
