Kyosho Evolva
#1381
tamidion - depends on your skill level, how much you want to spend, etc.... If you are wanting an OS, look at the OS Spec V II (I think). You need a .21 size motor at any rate. You really don't need anything too expensive or powerful starting off. I started with a Novarossi R1 WC (I got a good deal from a good friend).
Acid - the Evolva clutch shims up much like the Serpent clutches. Shims go on the outside of the thrust bearing to set clutch gap. Shims go before the inner bearing to keep the bell off the shoe and to set end play. I normally set my gap at 0.5 mm and end play at about .2 mm or so.
#1382
Thanks bro Darkangel, I am very new in 1/8 but had been playing 1/10 for years. Thats why I am a begineer for Evolva and thinking maybe OS is a good engine for begineer. How about OS VG or VZ-R Turbo? Thanks in advance.
#1383
Regards
Acid
#1384
I would probably go with the VZ II Turbo out of those two. You will be down on power/torque compared with the other motors in this class, but you should be alright.
If you haven't driven one of these before (this is my second year in this class); the car will steer as much with the amount of throttle you are adding as the amount of mechanical steering you add. Don't try to drive the car like a nitro touring car.
#1386
Thanks bro Darkangel & Srad. Will try to get get the engine this weekend.
#1388
Originally Posted by RRRoy23
Picco P9 Evo 2 is also a good choice.
Also which muffler & manifold is best? Thanks in advance.
#1390
Originally Posted by tamidion
Thanks bro RRRoy23, for beginner like me, which is better? Picco or OS? Need advise bro...
http://rctech.net/forum/showthread.php?t=159112&page=3
this is the picco p9 thread. I would say the Picco will be a better choice than the OS. You will not be disappointed with the power. The price is around $300.
#1391
check out this link.
#1393
Thanks bro. shall check it out this weekend.
#1395
Evolva
From there I went to the Rex 321P,and the Kangaroo engine.
I still get smoked with the experts in 1/8 scale, but it does take time.
The OS will serve you well.
