Old 05-28-2007, 07:02 AM   #1381
tamidion - depends on your skill level, how much you want to spend, etc.... If you are wanting an OS, look at the OS Spec V II (I think). You need a .21 size motor at any rate. You really don't need anything too expensive or powerful starting off. I started with a Novarossi R1 WC (I got a good deal from a good friend).
Acid - the Evolva clutch shims up much like the Serpent clutches. Shims go on the outside of the thrust bearing to set clutch gap. Shims go before the inner bearing to keep the bell off the shoe and to set end play. I normally set my gap at 0.5 mm and end play at about .2 mm or so.
darkangel is offline   Reply With Quote
Old 05-28-2007, 07:48 AM   #1382
Send a message via MSN to tamidion
Thanks bro Darkangel, I am very new in 1/8 but had been playing 1/10 for years. Thats why I am a begineer for Evolva and thinking maybe OS is a good engine for begineer. How about OS VG or VZ-R Turbo? Thanks in advance.
tamidion is offline   Reply With Quote
Old 05-28-2007, 08:02 AM   #1383
Thanks darkangel. Yeah, after going through the article, I see the clutch setup is similar to the Serpent Centax.
Regards
Acid
Acid is offline   Reply With Quote
Old 05-28-2007, 08:34 AM   #1384
I would probably go with the VZ II Turbo out of those two. You will be down on power/torque compared with the other motors in this class, but you should be alright.
If you haven't driven one of these before (this is my second year in this class); the car will steer as much with the amount of throttle you are adding as the amount of mechanical steering you add. Don't try to drive the car like a nitro touring car.
Old 05-28-2007, 10:21 AM   #1385
SRAD's Avatar
The VZ-R version 2 is the OS onroad .21......that's the one you want to use. If you are fairly new....it will be more than enough to get you in trouble!!!
SRAD is offline   Reply With Quote
Old 05-28-2007, 06:19 PM   #1386
Thanks bro Darkangel & Srad. Will try to get get the engine this weekend.
Old 05-28-2007, 07:11 PM   #1387
RRRoy23's Avatar
Picco P9 Evo 2 is also a good choice.
ARC R11, UF1 Team Force India, Tamiya F104 PRO Black
RRRoy23 is offline   Reply With Quote
Old 05-28-2007, 08:04 PM   #1388
Thanks bro RRRoy23, for beginner like me, which is better? Picco or OS? Need advise bro...
Also which muffler & manifold is best? Thanks in advance.
Old 05-28-2007, 09:00 PM   #1389
gashuffer's Avatar
Trader Rating: 48 (100%+)
The P9 is a great engine, I just broke mine in this weekend and it's fast. 2052 pipe with a 6 ringer and you're gold
T-Sal
gashuffer is offline   Reply With Quote
Old 05-28-2007, 11:03 PM   #1390
RRRoy23's Avatar
check out this link.
http://rctech.net/forum/showthread.php?t=159112&page=3
this is the picco p9 thread. I would say the Picco will be a better choice than the OS. You will not be disappointed with the power. The price is around $300.
Old 05-29-2007, 04:51 AM   #1391
Thanks bro RRRoy23. Will check on Picco as well. How much would it cost for the entire set of engine + muffler & manifold?
Old 05-29-2007, 10:55 AM   #1392
gashuffer's Avatar
289 engine, pipe79, mani 49, I know Sam at Kamikaze has it.
T-Sal
Old 05-30-2007, 02:11 AM   #1393
Thanks bro. shall check it out this weekend.
Old 06-02-2007, 10:35 AM   #1394
RRRoy23's Avatar
Were you able to check out the engine and pipe?
Old 06-02-2007, 11:42 AM   #1395
Trader Rating: 18 (100%+)
Default Evolva
I was just getting intro 1/8 on-road, and bought the new OS Version 2 -21 for my first engine. Believe me, it is more than enough to get you into trouble with. I think I only paid something like $245.00 for it new.
From there I went to the Rex 321P,and the Kangaroo engine.
I still get smoked with the experts in 1/8 scale, but it does take time.
The OS will serve you well.
brc358 is offline   Reply With Quote
Kyosho Evolva M3 tomkelley Nitro On-Road 1002 05-19-2015 08:49 AM
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
