Hot Bodies Cyclone
#5179
Please, could someone help me? I need to know a good starting gear ratio for the Cyclone S. The stock spur gear was to small. What spur and pinion combo works in the car. I will be running on asphalt my first time in a long while with a TC. I have been mainly running 12th scale. I have seen the setups for mod, but I have not seen setups for stock. The motor that is going to be used is CO27. Any help would be greatly appreciated. Thanks again.
#5181
Originally Posted by 2-Bad
I heard you were getting a red car Bob.... not true
#5182
Originally Posted by Skill
Leaning the shocks inwards tends to create more grip and allows the car to roll more in the corners.
this can be a valuable tool for bumps. it can also simulate a softer spring to a degree, since the spring may be initially as soft as the next step spring, but get a little stiffer with travel.
#5183
Just completed building my Cyclone. The kit comes with a 100t spur. I'm using a Novak Brushless 4.5. Novak recommends running a final of 9.75-10..25 with this motor. Here is my problem: With the 100t spur you have to run a 25t pinion to get a final of 9.75. At 25/100 the pinion does not get even close to mesh up. I can get to 9.75 at 32/128, but I don't know if the large spur would clear the rear graphite brace. Who else is running a Novak 4.5 in this car and what gear ratio are you running? Thanks so much.
Ron
Ron
#5184
Ron
108 is the largest you can go on the cyclone dont know what you should run with the 4.5 but I have seen it posted at around 10 to 1
#5185
Thanks Dave.
Do you know if the aluminum heatsink bulkhead brace allows for a larger spur?
#5187
Originally Posted by floodo1
the car rolls because as you lean the shock in you decrease the stiffness of the shock, both oil and spring. you also decrease the linearity (softer initially, then ramps up).
What he said.
#5189
Originally Posted by DavidAlford
108 is the biggest you can get on the car without some work. 110 pokes out the bottom just enough to make it not worth trying. With the new aluminum heatsink you have no problem with either gear.
can you run 48p spurs in a cyclone?
