T.O.P. Racing "Photon" 1/10 EP Touring Car
#8626
Thanks for the info guys! Getting back into high end 1/10th touring after doing 1/8th offroad for the past few years. The Photon has been an easy build so far with some very minor issues but I can't wait to get this thing on the track.
Guess I'll slap on a servo saver. Any recommendations for ones that just seem to fit well?
Lastly, will the stock aluminum bones for the front bend easily on a slight tap with the boards?
#8627
servo saver
hi dan
currently i am using the servo saver that xray brought out earlier this year with no problems,prior to that i was using the standard one that top have also with no problems
get the steel bones for the front they will serve you much better than the alloy ones
#8629
#8630
I thought I would throw this over here. before I put it on the for sale section I'm selling my EJ chassis. Only 2 carpet races on it!! Love IT! some stuff came up..
Shoot me a PM.. Thinking $65 shipped (Lower 48). open to offers.. if international you pay for shipping
#8632
This is probably the one that you are talking about:
http://www.nexusracing.com/product_i...ab6f9260d743d0
#8634
Completed the kit a few days ago...sexy in red.
Built it with the main belt on the battery side, will need to get some spacers for the side piece battery retainer. Little bit disappointed the upper deck gets in the way of the battery terminal connections but at least the battery will be pushed out more to even out the L/R weight distribution.
#8635
gear diff
does anyone know if the gear diff from the TC6.1 will work in the Photon?
#8636
if anyone is insterested pm me, i have a used exotek chassis for sale.
http://www.rctech.net/forum/r-c-item...n-chassis.html
#8637
I have fitted a Spec r and Yokomo diffs on my Photon which also fits the TC6 so big chance it will. Just had to shim it and also use the different diff blades.
#8638
#8639
is yokomo geardiff as smooth as xray diff?
I tried to rotate my friend's xray diff by hand, it is very smooth, and no leakage (from their experience).
I couldn't find yokomo diff in our local shop, so I just want to make sure how smooth it is before I order it from the online store.
#8640
running modified touring is a great way (although somewhat expensive when mistakes happen) to break in new gear diffs
