Yokomo MR-4TC SD
what do you suggest for the center drive shaft replacement ? I'm thinking to retire the stock shaft and change to something lighter and faster spool?...... but something cheap please
Spool Set-Up
Any suggestions for the CGM?
And can the Yokomo Carbon Prop Shaft handle the spool or shall I go back to the alum sprop shaft?
Does yokomo have a 6 degree c-hub?
I used to use a spool on a Warp TC3? will I expect the CGM to react in almost the same way?
Thanks!! Lem
Thanks!! Lem
Re: Spool Set-Up
Thanks!! Lem
Thanks!! Lem
Matt
Thanks, you've been really helpful!
Just finished this beuty, awsome car
I will look at the camber and toe-angles when i arrive at the track tomorrow.
nice to see the bulkheads anodized blue instead of silver...
very tempted to get one..
I just ordered a spool yesterday and would like to know what I can expect different in handling. Also what changes to the setup are likely?
about setting your car up.....i have experience runnign spool only on nitro cars......the main difference between using a front spool to diffs is that your front suspension should be softened (both damper oil and spring) and maybe the shock position can be changed.......more vertically makes your car to react faster......and it's a must at least for nitro racing, because the initial steering response is a little bit sluggish running a spool.......don't know if it will work for electric because nitro tracks are much bigger than electric tracks and less response sometimes helps when running electric at very tight tracks.....
You can get the spool from www.speedtechrc.com , go to "Go Shop at Speed Tech," then to the aftermarket parts section, and select the speedtech parts, you'll find the Yokomo spool there.
Originally posted by SalvadoriRacing
did you order online??? where?
Speed Tech has a lot of good parts for the Yokomo. I've been dealing with them for years. I looked all over the web for a spool and finally Speed Tech got them in stock again. So the spool will make the car a little sluggish going into the corner but should give it more on power steering correct.
yes.....
only the steering response is sluggish, but a car with spool usually can carry higher corner speed.....
the speedtech spool works with the original diff gears/??
It works with the Front One Way Gear, that's the one I use.
two things guys, if your interested in a spool, a little birdie told me the guy making them won't be able to soon.
2. woo hoo, my sdw came today
yokomo
stock yokomo BRAND new never raced just tested total runtime of like 2 or 3 minutes decided i will stick with oval lmk 275 plus ship it comes with custom body.lmk [email protected]
