Old 01-05-2005, 05:08 AM   #11521
asw7576's Avatar
what do you suggest for the center drive shaft replacement ? I'm thinking to retire the stock shaft and change to something lighter and faster spool?...... but something cheap please
Old 01-05-2005, 05:32 AM   #11522
lem2's Avatar
Default Spool Set-Up
Any suggestions for the CGM?
And can the Yokomo Carbon Prop Shaft handle the spool or shall I go back to the alum sprop shaft?
Does yokomo have a 6 degree c-hub?
I used to use a spool on a Warp TC3? will I expect the CGM to react in almost the same way?
Thanks!! Lem
lem2 is offline   Reply With Quote
Old 01-05-2005, 08:29 AM   #11523
Matt Howard's Avatar
try the tobee center shaft or the new yokomo hollow one. I've used the tobee shaft with modifieds and it held up fine. I've yet to try one of the new hollow shafts but they're made by team bomber and they have a really good reputation on their other shafts.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-05-2005, 08:33 AM   #11524
Default Re: Spool Set-Up
Thanks!! Lem
I would use the stock center shaft, the old graphite center shaft from yokomo will twist with a stock motor installed. They have a new hollow center shaft made by team bomber that should be very good. Yokomo only has 4 deg hubs at the moment. If you've driven a spool car before then you should have no problem with the CGM, it reacts the same as the tc3 as far as setup changes go.
RCTech #361
Old 01-05-2005, 08:47 AM   #11525
lem2's Avatar
Default Matt
Thanks, you've been really helpful!
Old 01-05-2005, 02:50 PM   #11526
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Just finished this beuty, awsome car
I will look at the camber and toe-angles when i arrive at the track tomorrow.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 01-05-2005, 03:46 PM   #11527
rc-zombies's Avatar
very nice...
nice to see the bulkheads anodized blue instead of silver...
very tempted to get one..
Old 01-05-2005, 05:31 PM   #11528
I just ordered a spool yesterday and would like to know what I can expect different in handling. Also what changes to the setup are likely?
kmorast is offline   Reply With Quote
Old 01-05-2005, 05:40 PM   #11529
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
did you order online??? where?
about setting your car up.....i have experience runnign spool only on nitro cars......the main difference between using a front spool to diffs is that your front suspension should be softened (both damper oil and spring) and maybe the shock position can be changed.......more vertically makes your car to react faster......and it's a must at least for nitro racing, because the initial steering response is a little bit sluggish running a spool.......don't know if it will work for electric because nitro tracks are much bigger than electric tracks and less response sometimes helps when running electric at very tight tracks.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-05-2005, 05:42 PM   #11530
rc_bam226's Avatar
You can get the spool from www.speedtechrc.com , go to "Go Shop at Speed Tech," then to the aftermarket parts section, and select the speedtech parts, you'll find the Yokomo spool there.
rc_bam226 is offline   Reply With Quote
Old 01-05-2005, 05:50 PM   #11531
Speed Tech has a lot of good parts for the Yokomo. I've been dealing with them for years. I looked all over the web for a spool and finally Speed Tech got them in stock again. So the spool will make the car a little sluggish going into the corner but should give it more on power steering correct.
Old 01-05-2005, 05:54 PM   #11532
yes.....
only the steering response is sluggish, but a car with spool usually can carry higher corner speed.....
the speedtech spool works with the original diff gears/??
Salvadori Racing
Old 01-05-2005, 05:58 PM   #11533
rc_bam226's Avatar
It works with the Front One Way Gear, that's the one I use.
Old 01-05-2005, 07:02 PM   #11534
Registered User
ritchie's Avatar
two things guys, if your interested in a spool, a little birdie told me the guy making them won't be able to soon.
2. woo hoo, my sdw came today
ritchie is offline   Reply With Quote
Old 01-05-2005, 07:05 PM   #11535
Default yokomo
stock yokomo BRAND new never raced just tested total runtime of like 2 or 3 minutes decided i will stick with oval lmk 275 plus ship it comes with custom body.lmk [email protected]
yokomo7 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
