Team Associated TC4
#8971
Originally Posted by DaveW
Its good to see ya come back to your roots Brandon. Have ya talked to KT lately?
#8972
It makes the buzzing sound all the time. If its the potentionmeter's problem, how do I get it replaced?
Does it make the buzzing sound when attached to the steering linkage, or does it buzz all the time with no servo horn attached? If it is NOT attached to the steering linkage and it buzzes all the time, then the potentiometer is most likely shot in the servo, and it should be replaced or repaired. If it only buzzes when it is attached to the steering linkage then either something is binding in your steering linkage and/or it IS a weak servo and it just doesnt have the strength to move the linkage completely to neutral, again, check to be sure your steering linkage moves freely back and forth without the servo attached. If everything moves fine with minimal binding, and the servo still buzzes, you might want to check into a better servo. Something in your price range with a minimum of 75oz/in of torque, and a transit speed of your choice would be a wise investment. One of the first and best upgrades to your TC, next to driving/practice time, it a good solid servo.
#8973
Front Suspension Tuning
Hi,
When I'm coming off the straight at my local club (foam on carpet) and into the sweeper, I can see that the inside front wheel is up off the ground.
What adjustment would help keep it down best?
I have 4mm of droop and Purple springs up front (3rd stiffest).
I'm thinking 1 - 1.5 mm of added droop and maybe Gold springs.
Not sure that it's having much of an effect, but I cannot see how having a wheel off the ground helps.
#8974
I am looking for a good rollout for a TC4 on Oval, Also I was wondering if I am calculating the rollout correctly...What I was told to do by a person at the track is
(tire diameter(inches)x(3.14)x(pinion) all divided by the spur.But from other rollout formulas I have seen they were using the transmission ratio...Can you guys point me in the right direction, thank you Jeff
#8977
Originally Posted by adamge
4mm droop?!?! That's way more than usual. Most carpet foam setups use 0-2.5mm droop.
#8978
Transmission ratio
Hi,
What is the transmission gearing ratio for a FT TC4? 2.5 like the TC3 or is it different. AE has nothing on it's site (that I can see).
Oh, yes, the droop I'm reading is the 4 on the droop gauge.
Mike
Mike
#8979
Originally Posted by MleedM
Hi,
Mike
Mike
#8980
Ratio
Originally Posted by ShaunMac
FT TC4 transmission ratio is 2.5
thanks
#8981
I am still looking for a good rollout to start at and a good way to calculate it. Any help would be greatly appretiated
#8982
It gives you rollout
What is rollout?
#8983
I wasent really having the trouble finding the sites to calculate it, but rather I was looking for what a good starting point would be to try and get my rollout to...I am racing oval carpet on a fairly large track...I was also looking for the real formula to work with, since I do not have the computer at the track with me...Thanks again Jeff
#8984
Tire Diameter x 3.14/FinalDriveRatio = Rollout........FDR = Spur/Pinion x Transmission Ratio(2.5 on TC4)
example: 57mm x 3.14/7.0 = 25.57mm
Rollout = 25.57mm
Rollout is the distance the car will travel with one revolution of the motor.
Rollout = 25.57mm
#8985
thank you, Do you have any suggestions on what a good starting point for rollout would be though? right now I am running a 29t/72t with a stock motor (epic)
