Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 04-27-2012, 09:28 PM
  #10516
The only way to remove tweak from the tc4 is to run lightweight electronics: the electronics side of the Car has to weigh under 310grams to match most lipo packs... I run my Cars tweaked and adjust to it ...
bertrandsv87 is offline
Old 04-27-2012, 10:26 PM
  #10517
Rodarbal's Avatar
Trader Rating: 49 (100%+)
Originally Posted by ducatidesmo
how are people handling the motormount/silver can issue? is there another mount I can buy?
Originally Posted by THEBIGBULL
Use a drill bit the size of the bushing and carefully drill out the teardrop, Key word "Carefully", best if you have access to a drill press. Don't go for the full size on one pass, Use larger drill bits until it fits, Good luck!!! Yes it is doable!!!!
Here's what I use on my drill press. I've drilled out several motor mount cams for fellow competitors racing with TC3/4s in our local silver can class.
Rodarbal is offline
Old 04-28-2012, 12:38 PM
  #10518
Trader Rating: 41 (100%+)
I use a 1/12 Servo Futaba S9602, a Novak 1/18th scale Mongoose for my 25.5 T Novak VTA Motor
and I add 7g to the Electronics side to Balance my battery which is only 310g
But I also put 130g in the center line under the Driveshaft in the middle of the car to make weight
goes fast
jdeadman is offline
Old 04-28-2012, 10:11 PM
  #10519
Nice way to get it balanced Jason !
Old 04-29-2012, 12:02 PM
  #10520
Rdog's Avatar
Trader Rating: 83 (100%+)
Check if out fellas in your interested
http://www.rctech.net/forum/r-c-item...attery-rx.html
Rdog is offline
Old 05-02-2012, 09:22 PM
  #10521
Trader Rating: 15 (100%+)
Default My TC4 keeps going right.
I have a TC4 setup for VTA. Everything is stock except that I put a solid axel in the front. I'm running the Novak 25.5 Ballstic and Novak Edge ESC. I also have the Saxov 1258TG servo. As for the battery, I'm running the GensAce 5000mah 40c.
I've adjusted camber/toe/ride height, etc... but the car always goes to the right. Just to test, I intentionally set my steering to the left but the car will still go right. What am I doing wrong?
saxo is offline
Old 05-02-2012, 10:45 PM
  #10522
You have to Check your tire shimming, steering rack play, ball cup play, and grind the steering rack bolt that might hit the main shaft cup . Also make sure the steering turbuckle that connects to the servo stays clear of the rotating shaft......
Old 05-05-2012, 09:42 PM
  #10523
Thanks for the feedback. I checked those things you said and they "seem" right to me although I'm not an expert. I did notice something. This only seems to happen at the start. It's as if there is too much torque on the rear tires. Right off the bat, the car goes right...reaches near max speed then goes straight. I then checked and notice the chassis is "tweaked." I hope I'm using the right terminology.
So I tried raising the rear and the LEFT tire lifts earlier than the right REAR. I check the front and it's the opposite. So the front RIGHT tire comes up before the front LEFT. It's opposite corners.
Could this be my problem and if so, how do you adjust a TC4 tub chassis?
saxo is offline
Old 05-05-2012, 10:16 PM
  #10524
Both left and right Tires on either the front or the rear should come Off the ground at the same time. To adjust that, you need to tighten the droop screws that are located in the A arms until you get both Tires getting Off the ground at the same time. You also need to make your suspension uptravel about 3mm before the Tires come Off the ground...
Old 05-06-2012, 08:44 AM
  #10525
Also Saxo, if the front right tire comes up before the front left, you will inevitably turn right on sudden acceleration. If the rear left comes up before the rear right, you will spin easier turning left than turning right........
Old 05-07-2012, 10:37 AM
  #10526
Thanks all for your suggestions. I had to tighten the rear diff cause it was too loose. After that I adjust the ride height and ensure camber, toe, etc...were set correctly. Now my TC4 screams straight! So happy. Thanks again.
saxo is offline
Old 05-08-2012, 07:27 AM
  #10527
y2kgtp's Avatar
Trader Rating: 35 (100%+)
I have a 200mm HPI Mustang GT-R I want to run on my TC4 sport, but I picked up the standard offset X-pattern tires.
What is a good offset to use to run this body, any suggestions? I think the 190mm wheelbase might look funny on a 200mm body.
Everything is still in the package as was deciding on what to do.
I picked up a 190mm S2000 body as well, but really don't care for the looks of it.
EDIT:
Also, what would be a good start for gearing for 17.5T ? I have a Speed Passion combo to go in this, but not a clue on where to start for gearing.
EDIT EDIT:
What is the smallest spur I can fit on here? I'd like to run the 59T if I could.
y2kgtp is offline
Old 05-10-2012, 02:42 PM
  #10528
I have a TC4 setup for VTA so by rule, the front wheel/tires are +3mm offset and the rears are +6mm offset. Looks cool since VTA bodies are 200mm in width. I did put on a 190mm sedan body using the same wheels/tires and it looks a bit funny.
So I sugest you start out with 3mm offset.
saxo is offline
Old 05-10-2012, 04:12 PM
  #10529
phildoggg's Avatar
Trader Rating: 24 (100%+)
Robinson racing makes 49,52,55,60 tooth spur gears for them part numbers are rrp1855 (55t spur, just add the tooth count after the 18)
phildoggg is offline
Old 05-11-2012, 10:03 AM
  #10530
mac112's Avatar
HI,
I have a TC4. i run a 10.5 LRP K4 motor with a 72/25 set up. i mostly bash with friends on black top. is this a good gear set up for this kind of motor?? Also i have here a lot about shiming the TC4. i shimed the steering rack, what other areas do i need to shim and whear do i get the shims from aside from Assoicated for the Tc3/4??.
Mac.
mac112 is offline
