Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 04-04-2012, 10:18 AM
  #10501
Trader Rating: 84 (100%+)
Originally Posted by Conrad
I have a bag of wishbones, some c/f some plastic is their anyway to tell the difference once the c/f markings are worn off as both appear the same...?
The c/f parts are lighter in color and are more grey. They have visibly more fibers in them.
jeff jenkins is offline
Old 04-04-2012, 08:29 PM
  #10502
Smile
Originally Posted by jdeadman
There is a great setup on the AE site for asphalt for the TC4 That's the one I use for VTA
Which TC4 setup sheet from the Assoc site do you use for VTA there is more than one.
I found a Barry Baker setup for the TC3 on that site that I use for outdoor asphalt VTA and the car is "DIALED" !!!! I recently acquired a FTTC4 like new and I also have a carbon tub TC4 and I'm not sure which to try first. I'm going to start the season with the TC3 as it was very competitive last year. I was thinking of trying the TC3 set up on the TC4 as some where to start. Thanks for any suggestions.
THEBIGBULL is offline
Old 04-04-2012, 10:47 PM
  #10503
Trader Rating: 41 (100%+)
I use with some Modifications for our local track
http://www.teamassociated.com/pdf/ca...yrace_2006.pdf
The Only changes is sprung a little lighter on the rear and the front inner-upper camber link mount all the way in and as high as possible
jdeadman is offline
Old 04-11-2012, 01:53 PM
  #10504
SHOEADDICT's Avatar
ANYONE HAVE SOME EXTRA ALLUMINUM PARTS LAYING AROUND FOR A TC4? PLEASE HELP, THANX
SHOEADDICT is offline
Old 04-12-2012, 08:17 AM
  #10505
Boomer's Avatar
WHAT? I CAN'T HEAR YOU WITH THE CAPS LOCK on. . .
Boomer is offline
Old 04-16-2012, 04:05 PM
  #10506
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Ordered a TC4 Club and Speed Passion 17.5T for some future spec racing. I was thinking of getting an Ofna JL10e, but local parts availability for the AE made it a easier choice.
y2kgtp is offline
Old 04-17-2012, 08:24 AM
  #10507
y2kgtp's Avatar
Are they spacers available to bump from 190mm to 200mm? I have a 190mm and 200mm body, and would like to flip back and forth with the HPI tires I already have.
I have a set of mounted HPI's 4702 that I presume will make the car 190mm.
y2kgtp is offline
Old 04-19-2012, 12:31 PM
  #10508
how are people handling the motormount/silver can issue? is there another mount I can buy?
ducatidesmo is offline
Old 04-19-2012, 08:56 PM
  #10509
Use a drill bit the size of the bushing and carefully drill out the teardrop, Key word "Carefully", best if you have access to a drill press. Don't go for the full size on one pass, Use larger drill bits until it fits, Good luck!!! Yes it is doable!!!!
Old 04-24-2012, 01:32 PM
  #10510
y2kgtp's Avatar
Is there a way to change the width of the car by shimming? I have both 190mm and 200mm bodies and would like to run both.
y2kgtp is offline
Old 04-24-2012, 04:35 PM
  #10511
No way to shim to 200mm !
bertrandsv87 is offline
Old 04-26-2012, 11:12 AM
  #10512
Trader Rating: 15 (100%+)
Default TC4 + Solid Front Axel = chatter?
So I decided to swap out the front TC4 diff and put in a solid axel for the front. With the Xrays, you can get the ECS to minimize the chatter. How do you address this with the TC4?
saxo is offline
Old 04-26-2012, 08:35 PM
  #10513
To remedy the front chatter , I have been using the Losi lcd's (#losa3344), but it requires some dremeling of the caster blocks, or you can instead use losi caster blocks....
Old 04-26-2012, 10:06 PM
  #10514
By the way, it's been six years and no sign of excessive wear yet!
Old 04-27-2012, 09:05 AM
  #10515
Conrad's Avatar
Thats good to hear bertrand, I read some of your olds posts about the LCD's, I have a set waiting to go on the car with losi carriers but the chassis is tweaked to hell so until I move my ass and make a chassis the car is on holiday
Conrad is offline
