HPI R40 Nitro Car Forum
#7126
Originally Posted by AMGRacer
I have LW chassis
LW batt (42g) (Thats 20 grams there)
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
AMB personal transponder
body (110 grams painted)
NS12 S3 A1 motor
Skyline racing pipe (dunno if lighter)
Oneway front diff (thats about 20-30grams there if I remember right)
Depends on your tires, mine are foam and 59mm (about 10g per tire lighter than rubber)
I have graphite lower front pin braces
Graphite side brace
Graphite arm set (a bit lighter as well)
The last 3 items are really the only "hopups" on my 2004 kit.
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
NS12 S3 A1 motor
Graphite side brace
Looks like it is the battery and one-way mostly. So you replaced the hinge pins with graphite rods? I am still considering the GPM titanium parts you listed previously. Kinda weird thought, they list the weight of the pivot balls at similar to the stock ones. I thought you had stated they were indeed lighter though.
BTW - The BSR rubber capped tires w/ JACO rims are the same weight as my foams; 25 g each. You should try the RED Pro Lites once.
http://www.bsr-racing.com
Thanks for the info.
#7127
JAG' you are correct, Actually my car now weighs around 1826 grams with the hpi M3 painted body, I guess I really need to work on the battery, minne weighs 130 grams... thats too much, but for now Im happy with the results lol... I will try a run at the impacts this weekend and see what happens...
#7128
Originally Posted by nsxshogun
Klander show some pics of the deck.
#7129
#7130
I have LW chassis
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
NS12 S3 A1 motor
Graphite side brace
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
NS12 S3 A1 motor
Graphite side brace
#7131
My foams are 19g for the fronts and 22g for the rears, so there is a bit more weight. I have replaced the lower purple front hingepin braces, not the hingepins themselves. My latest car does not have the GPM pivotballs in it, I am using the standard items. They definately were lighter however, I cant find my notes with exactly how much.
#7132
Originally Posted by KLANDERMAN
Hey you guys I was weighing my engine and it was at 402 grams with the header, tuned pipe, filter element... I dont know if thats heavy, I have a team orion wasp .12 3 port engine__
#7133
My world champ edition Sirio with pipe and filter and no engine mounts is 303g.
Ouch! Thats 100 grams less then the Wasp! Even if Klanderman had his engine mounts on, they can't weigh that much. Amazing. I always assumed that all engines were fairly close in weight.
#7134
#7135
I have LW chassis
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
NS12 S3 A1 motor
Graphite side brace
LW 2-speed
mid and main shafts
graphite towers
alum shocks
titanium screws
NS12 S3 A1 motor
Graphite side brace
- Titanium pivot balls
- 5 AAA reciever pack Homemade glued to cover
- RD Logics pipe
- 59mm Jacos
- Protoform Mazda 6
Now its 1770g
So how where do I find another 45g for ROAR minimum?
Andy
#7136
#7137
I just ordered a lola from ace hardware. So all my stuff motor, parts. and body and tires should be here by next wendsay. I hope to hit the track on thursday. Now I'm wondering how should I paint it. Klander do you mind if I take your design!!
#7138
Most likely that's quite a bit of weight there. I never thought of tossing anything more on the R40, but I guess it would benefit from the engine mounts and LW chassis. I ordered two sets of LW spur gears for my R40. The 8th will be kept aside till I learn how to drive it more and then it will be running at the track. For now the R40 is what I'm very used to. The floating rear mount trick is scrap as I'd need an actual working one that fits the car properly. They work great with even TC bodies. Right now just gonna get those two upgrades and then slowly build up on spare parts for each car as right now I'm still trying to get a real car. It's quite hard at the moment trying to find a good deal.
#7139
Originally Posted by StoneMan
Our car is the same except
- RD Logics pipe
- 59mm Jacos
- Protoform Mazda 6
Now its 1770g
Andy
- RD Logics pipe
- 59mm Jacos
- Protoform Mazda 6
Now its 1770g
Andy
#7140
