Awesomatix A800/A800R
#5011
The top curve is an evo that does great at my local track on the old style pss. The bottom is the new style pss. Should I be looking to get the ride height to be in the flat spot of the lower curve? The green line in the curve is where it should be at ride height. Both cars sit level at about 5.4mm and 300 grams of mass. You can really see what happens from bending the hook when you measure this way. The blue line on the id motor was doing some crazy stuff until i bent it out to try and get it similar to the above evo. It looked more like an s.
some general observations. I can see that a high slope in the beginning make a big difference to how much preload I have to add to balance the car. In some cases I save 2mm of stroke.
When the force starts on these curves I set 0 position. I have figured out how to modify the shape of the curves by bending the eyelet to mimic a known “good” curve or to match left to right. I have a balanced chassis on scales and on balance pegs. The friction in both left and right are the same. One thing I have noticed is that if I synch springs initial and dynamic curve the ride height is slightly off on one side. Ive checked friction and weight several times and the eyelets never hit the hard stop. I have to assume some tolerance is off and im wondering if Oleg has some suggestions. Im wondering if I should shim one side up to the other to retain spring and ride height synchronization. Or maybe the springs just have a .1 lb deviation tolerance.
#5012
Delete
#5015
We will have another tech tip session tomorrow afternoon on diffs!
#5017
Racermac73 it's a good thing we didn't become big winners... Our heads would of been HUGE
Hope your staying safe!
#5018
#5019
I’m building a new MMX and don’t think i have the front universal right, it can be moved in all directions but there’s a lot of friction at a point. Hard to explained. This is the US version axles. I did it according to the instructions and have the sleeve over it so everything seems to be in its place...any thoughts?? And by the way, the quality of these parts (so far) is amazing!
#5020
#5021
#5023
Thanks! The reason for that is simple, I’ve been running AX continuously since 2013, so I think other than maybe the Danilchicks, I probably have the most experience with the car of anyone in the US I’ve lived through every iteration of the shaft car to the belt car to now the mid motor car. Also I’m 29 so maybe not quite as young as I look. That hat hides my gray hairs
Anyway, enough of the nostalgia. It is very cool to see your videos Mike , you make it look easy. Keep em up, we are fortunate you are doing them, and thanks for the shout out to me and my bro.
Cheers,
Jake Danilchik
#5025
The pre production car was at iic and other events prior to the official first production car that was shipped in October 2011. Perhaps Oleg may have sold you an early production car, if that’s the case, kudos to you ! :-) I just meant *virtually* nobody had seen the car.
Jake
Jake
