Tamiya F104 Version 2 >
Like Tree2Likes
Old 02-11-2013, 03:05 PM
  #946
There is no non-pro version of the F104 V2 currently
InspGadgt is offline
Old 02-11-2013, 04:53 PM
  #947
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by viet
I did. I don't think they have the Pro kit in stock.
They do. I just checked.
However. If I were you I would wait for the titanium edition which will be about $270-300 unless you need one right now. That kit will include aluminum motor mount and a body, which you will need to buy anyway and they cost about $70+ if you buy separately.
edhchoe is offline
Old 02-11-2013, 05:11 PM
  #948
Trader Rating: 23 (100%+)
What's the eta on the titanium edition?
viet is offline
Old 02-11-2013, 06:08 PM
  #949
edhchoe's Avatar
Soon I hope.
It's in "coming soon" status which means it is in production or in transit.
So probably sometime later this month or early march.
edhchoe is offline
Old 02-12-2013, 05:13 PM
  #950
JoeGolf's Avatar
Help.......... I haven't run onroad since I had an F103L(Indycar) back in the early 90's. Ran that thing into the ground, and loved it.
Looking to get a new toy for the track, but with all the F104 models I have no idea what to do. It may or may not get raced, but will be on the track 90% of its run time. Indoor carpet, about 30x80'.
So the question is,
F104W-GP, F104V2, Black, Titanium? I don't even understand the differences between the V2 models at this point. I'm thinking I'll run rubber tires and probably 17.5 or 21.5 motor combo. Any input on chassis choice would be a HUGE help. Thanks, Joe
JoeGolf is offline
Old 02-12-2013, 06:05 PM
  #951
mtveten's Avatar
Trader Rating: 29 (100%+)
So the question is,
I would suggest any of the v2 models, the only difference between them is the color of the aluminum and the extra goodies included. With the v2 chassis kit you will need the upgrade motor mount, the black and titanium editions include it.
The w-gp is is designed for foams and would need more to to be rubber tire ready with less tunability
mtveten is offline
Old 02-12-2013, 06:19 PM
  #952
JoeGolf's Avatar
Perfect, thats the info I was looking for
JoeGolf is offline
Old 02-12-2013, 09:31 PM
  #953
RCformula1's Avatar
So the question is,
You might also be interested in our 2013 F1 Buyers Guide.
RCformula1 is offline
Old 02-13-2013, 10:00 AM
  #954
Thunderbunny's Avatar
Trader Rating: 27 (100%+)
Go with a 21.5. It is the standard if you plan on racing.
Thunderbunny is offline
Old 02-13-2013, 09:29 PM
  #955
RCformula1's Avatar
Here's the latest how-to article:
http://www.rcformula1.com.au/index.p...th-blinky-escs
We post new F1 content most days. If you'd like to receive notification in your Facebook news feed then please Like us on Facebook here.
Old 02-14-2013, 04:31 PM
  #956
cheROK1212's Avatar
Trader Rating: 13 (100%+)
Any idea on an ETA for the 2012 step nose body shell?
cheROK1212 is offline
Old 02-14-2013, 07:51 PM
  #957
whitrzac's Avatar
Trader Rating: 97 (100%+)
Who designed the shocks on the f104? they should be fired... It's probably the same person that included the plastic motor mount
I haven't seen a worst shock since.... Nope, it is the worst ever...
How are they suppose to work? both are mounted upside down, with no o-rings at that end, and a hole in the cap
I left a little part of myself on every piece of carbon that needed to be sealed... I don't remember my glue taking that long to dry
whitrzac is offline
Old 02-14-2013, 08:12 PM
  #958
edhchoe's Avatar
Use a sedan shock for the pitch and a friction roll shock from x1 chassis.
edhchoe is offline
Old 02-14-2013, 08:51 PM
  #959
You can thank AE for the design as they first came up with the concept of an even pressure shock. Its actually quite an ingenious idea...by having the shock shaft come out of both ends of the shock the pressure on both sides of the piston will always be the same making for the only truly neutral shock.
As for no o-rings....huh? I'm looking at the manual on line right now and there should be o-rings on both sides of the shock. Are you sure you assembled it right? There are 2 o-rings on the plastic cap side...one inside the cap and one around the outside of the cap. On the other side of the shock there is an o-ring in the bottom cap.
Old 02-15-2013, 06:56 AM
  #960
Surprised it took so long to be widespread, I have a Demon MF-1 1/12th scale that used this through shaft design from way back in 1983. The shock was borrowed from the 1981 PB Alpha 1/8th front suspension.
And yeah, there should be o-rings at both ends of the shock.
terry.sc is offline
