Yokomo MR-4TC SD
Re: Re: Ok I'd buy one but not eight....
Originally posted by pops
One good way to check your wheel bearings is to put them on the tip of a standard pencil. Soak and clean them with motor spray, them spin them on a pencil. You will feel any roughness through the pencil. Be sure to re-lube them before you use them again.
Re: Re: Re: Ok I'd buy one but not eight....
Originally posted by Mabuchi540
Well yes but I should be feeling anything but a smooth roll so to speak if i've just opened the packet surely?
Re: Re: Re: Re: Ok I'd buy one but not eight....
Just clean them with motor spray and spin them on a sharpend pencil, if they spin up they are OK. They should spin quite a long time, if they don't spin up, they're bad.
Re: Re: Re: Re: Re: Ok I'd buy one but not eight....
Do I need to take the sheilds of for this? And re-lube with what?
all eight of them felt well lets just say rough
you are not to fix or atemp to fix any defective parts; it voids any warranty and/or exchange you maybe intitled to.
nobodys quality control is perfect; thats why they warranty their products.
Originally posted by rovic
the right thing to do is return them from where you got them; if its a lhs, open the exchanged set and test the each before accepting them.
But if you really believe they are gritty, just return them, ceramics are expensive, and you should have good ones. I've used a couple of sets of Yokomo ceramics and have never had any problems.
Update......
If they are Yokomo bearings you will not have a problem in returning them, as long as you have not used them. You had to open the package in order to find out what you know and have now. Do not remove the seals though.
to late for the wheel bearings I took the sheilds off already. But here is what happened.
After cleaning them as suggested they did indeed spin remarkably freely.
However I then put the mearest drop of oil on them and of course they slow down a little bit but still all good but it's when I put the sheilds back on I noticed the problem as first mentioned returned.
So out comes the manifying glass to have a good look (and one of the other non wheel bearings in the kit to compare).
It appears on very close inspection that in at least one spot of every wheel bearing there is no viewable gap between the (I hope this make sense) the inner edge of the sheild and the outer edge of the center roller.
Sheild off no problems though. If they were anything but the wheel bearings I'd just take the sheilds off.
Yokomo is going to be selling Masami and Rayspeed versions of the KO ESC here shortly, they come out next month in japan, not sure on the release date for the states. www.yokomousa.com has the info in the new products section under february.
so now there are SIX versions of the same speed in the market......
KO, HARA, CORALLY, TAMIYA, YOKOMO and RAYSPEED.....
spraying out bearings
someday i will be good enough to run bearings with the grease cleaned out of them, for now im just learning what the different camberlink positions and setups do for the car.
you have to go slow, to go fast. quote from ae team manager.
Funny I could have sworn that the ESC Masami used to win the Worlds was the GM Racing SX12W in fact I am almost certain. So How could he have used the Ko Propo ESC????Just seem awfull fishy,,,,,
Just my two pennies.
Stephen <><
Stephen <><
Stephen <><
Stephen <><
- JB
Yes, I believe Masami's using GM ESC for both class at the Worlds.
For JMRCA he use KO VFS for 1:12 class. Dunno what he have used for the JMRCA 1:10 TC class
i can't find where matt said anyone used anything to win anything with. maybe its just me.
rovic, yea, i heard something about slower is faster.
ritchie,
how are things in the nw., the more i drive this cgm the faster it gets.
got a tip for you.
testing on gear ratios; run the 48p 72t spur. ive found that its surprisingly faster on acceleration than similar geared 64p spurs. it wont work well if you run lower than 10t.
got a tip for you.
