Old 01-31-2005, 01:24 PM   #12136
Default Re: Re: Ok I'd buy one but not eight....
Originally posted by pops
One good way to check your wheel bearings is to put them on the tip of a standard pencil. Soak and clean them with motor spray, them spin them on a pencil. You will feel any roughness through the pencil. Be sure to re-lube them before you use them again.
Well yes but I should be feeling anything but a smooth roll so to speak if i've just opened the packet surely?
Mabuchi540 is offline   Reply With Quote
Old 01-31-2005, 01:29 PM   #12137
Default Re: Re: Re: Ok I'd buy one but not eight....
Just clean them with motor spray and spin them on a sharpend pencil, if they spin up they are OK. They should spin quite a long time, if they don't spin up, they're bad.
pops is offline   Reply With Quote
Old 01-31-2005, 01:39 PM   #12138
Default Re: Re: Re: Re: Ok I'd buy one but not eight....
Do I need to take the sheilds of for this? And re-lube with what?
Old 01-31-2005, 02:46 PM   #12139
rc_bam226's Avatar
Default Re: Re: Re: Re: Re: Ok I'd buy one but not eight....
A thin lubricating oil, such as Trinity Royal Oil #RC4051, or any other synthetic bearing oil, which is thin, and flows kinda like water.
rc_bam226 is offline   Reply With Quote
Old 01-31-2005, 05:15 PM   #12140
rovic's Avatar
all eight of them felt well lets just say rough
the right thing to do is return them from where you got them; if its a lhs, open the exchanged set and test the each before accepting them.
you are not to fix or atemp to fix any defective parts; it voids any warranty and/or exchange you maybe intitled to.
nobodys quality control is perfect; thats why they warranty their products.
rovic is offline   Reply With Quote
Old 01-31-2005, 06:16 PM   #12141
If they are Yokomo bearings you will not have a problem in returning them, as long as you have not used them. You had to open the package in order to find out what you know and have now. Do not remove the seals though.
But if you really believe they are gritty, just return them, ceramics are expensive, and you should have good ones. I've used a couple of sets of Yokomo ceramics and have never had any problems.
Old 01-31-2005, 07:38 PM   #12142
Default Update......
to late for the wheel bearings I took the sheilds off already. But here is what happened.
After cleaning them as suggested they did indeed spin remarkably freely.
However I then put the mearest drop of oil on them and of course they slow down a little bit but still all good but it's when I put the sheilds back on I noticed the problem as first mentioned returned.
So out comes the manifying glass to have a good look (and one of the other non wheel bearings in the kit to compare).
It appears on very close inspection that in at least one spot of every wheel bearing there is no viewable gap between the (I hope this make sense) the inner edge of the sheild and the outer edge of the center roller.
Sheild off no problems though. If they were anything but the wheel bearings I'd just take the sheilds off.
Old 01-31-2005, 09:33 PM   #12143
Matt Howard's Avatar
Yokomo is going to be selling Masami and Rayspeed versions of the KO ESC here shortly, they come out next month in japan, not sure on the release date for the states. www.yokomousa.com has the info in the new products section under february.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-31-2005, 09:40 PM   #12144
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
so now there are SIX versions of the same speed in the market......
KO, HARA, CORALLY, TAMIYA, YOKOMO and RAYSPEED.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-31-2005, 10:08 PM   #12145
rovic's Avatar
Default spraying out bearings
someday i will be good enough to run bearings with the grease cleaned out of them, for now im just learning what the different camberlink positions and setups do for the car.
you have to go slow, to go fast. quote from ae team manager.
Old 01-31-2005, 10:26 PM   #12146
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Funny I could have sworn that the ESC Masami used to win the Worlds was the GM Racing SX12W in fact I am almost certain. So How could he have used the Ko Propo ESC????Just seem awfull fishy,,,,,
Just my two pennies.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-31-2005, 11:07 PM   #12147
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Stephen <><
I don't think Matt was saying Masami used his up-n-coming version of the KO; from what I read he was just saying that Yokomo is coming out with these versions. And even if Masami did...
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-31-2005, 11:08 PM   #12148
Regional Moderator
daniz24's Avatar
Yes, I believe Masami's using GM ESC for both class at the Worlds.
For JMRCA he use KO VFS for 1:12 class. Dunno what he have used for the JMRCA 1:10 TC class
daniz24 is offline   Reply With Quote
Old 01-31-2005, 11:26 PM   #12149
Registered User
ritchie's Avatar
i can't find where matt said anyone used anything to win anything with. maybe its just me.
rovic, yea, i heard something about slower is faster.
ritchie is offline   Reply With Quote
Old 01-31-2005, 11:39 PM   #12150
rovic's Avatar
ritchie,
how are things in the nw., the more i drive this cgm the faster it gets.
got a tip for you.
testing on gear ratios; run the 48p 72t spur. ive found that its surprisingly faster on acceleration than similar geared 64p spurs. it wont work well if you run lower than 10t.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
