Xray T1
#7156
Originally posted by evaa
its part number 305511, description is Layshaft Spring Steel Integr. Spur G. Adapter EVO2.
solid layshaft is the aluminum one with part number 305502 Solid Alu Central Layshaft Set ? am i right?
Try it out and see for yourself what is best suited for you...if budget will allow it
#7157
Originally posted by gido
Ok, I see what you mean about the layshaft spring steel...I've never tried it because I believe it's heavier than the aluminum solid layshaft. I prefer lightening that area beacause it is probably the most constant moving part.
happy racing
#7158
Originally posted by True R/C Racing
Also What do you guys think of ALUM shock bodies?
#7159
Thanks rough512 & evaa!
I have been to MYtsn so I will try some of what I found there.
Front:
Caster: 3mm clips
Camber: 1° neg.
Kickup: 0°
Servo saver position: ?
Eccentric upper arm position: Front holders upper hole / Rear Holder lower hole
One way diff
Springs: White short
Shock oil: 30WT
Damping: 2 holes closed
Shock top position: Outer hole, original T1 tower
Shock bottom position: Outer hole
Ride height: 5 mm
Toe in/out: 1° out
Droop setting: 2mm
Rear:
Camber: 1,5° neg.
Kickup: 0°, arms raised to top position
Wheelbase: middle (don’t remember how many mm’s)
One way centre layshaft tightened 100%
Springs: Yellow (Serpent)
Shock oil: 30WT
Damping: 1 hole closed
Camber link: Long and high on rear hub.
Ride height: 6 mm
Droop setting: 4mm
Balancing weights:
50g in the middle of chassis, between electronics
10g on each side of chassis rear
Rubber tires, Sorex 36
Protoform Stratus body, std wing
@rough512: I have not looked into the reactive caster. Can you explain?
Front:
Caster: 3mm clips
Camber: 1° neg.
Kickup: 0°
One way diff
Shock oil: 30WT
Ride height: 5 mm
Toe in/out: 1° out
Droop setting: 2mm
Rear:
Camber: 1,5° neg.
Shock oil: 30WT
Ride height: 6 mm
Droop setting: 4mm
Balancing weights:
#7160
Parts???????
Hey Guys,
Can somebody tell me where i can buy - XR-302000 (Alu suspension adjustable bulkheads + free tool set) from? anywhere which has an online website would be nice. I cant find this part anywhere
cheers
cheers
#7164
Originally posted by vassago
If you are racing the car you really need the ALU shock bodies in de rear. The plastics ones will break if you are hit from behind.
hence, i think in terms of durability, those plastic shocks are unquestionably tough.
#7165
Theywill break if you are hit, seen it happen lots of times. I think you are just lucky so far.
#7167
sure am, glad it hasnt hapened to me, have you replaced your plastic shock bodies with the alum ones? did you notice any change?
After the start I noticed a rear shock had come loose and I stopped after 1 lap.
In the 2nd final the same thing happened with another car. That car was using the composite shock bodies and one broke.
I don't know if you will notice a difference. I am just finishing my 2nd car which will have composite shocks so maybe I will notice a difference. May not.
(I plan to take the 2 alu. shocks off the front of my first car and put them on the rear of the second car)
#7168
Get the Alu shock housing.
Its worth the money and less pain during race day.
Furthermore, its easier to screw in the cap and the adjuster.
It wont be so easy to strip the thread on the shock body too.
As for performance, cant see or feel any.
#7169
Yo guys check this out!
X-ray is testing a new chassisplate!
#7170
And another picture of the new chassisplate.
