Old 05-27-2004, 01:19 AM   #7156
Originally posted by evaa
its part number 305511, description is Layshaft Spring Steel Integr. Spur G. Adapter EVO2.
solid layshaft is the aluminum one with part number 305502 Solid Alu Central Layshaft Set ? am i right?
Ok, I see what you mean about the layshaft spring steel...I've never tried it because I believe it's heavier than the aluminum solid layshaft. I prefer lightening that area beacause it is probably the most constant moving part.
Try it out and see for yourself what is best suited for you...if budget will allow it
gido is offline   Reply With Quote
Old 05-27-2004, 01:41 AM   #7157
evaa's Avatar
yep i plan on doing that, i know decreasing weight on the rotating mass is one of the secrets to speed.
happy racing
evaa is offline   Reply With Quote
Old 05-27-2004, 03:25 AM   #7158
Originally posted by True R/C Racing
Also What do you guys think of ALUM shock bodies?
If you are racing the car you really need the ALU shock bodies in de rear. The plastics ones will break if you are hit from behind.
vassago is offline   Reply With Quote
Old 05-27-2004, 03:34 AM   #7159
OleC's Avatar
Thanks rough512 & evaa!
I have been to MYtsn so I will try some of what I found there.
Front:
Caster: 3mm clips
Camber: 1 neg.
Kickup: 0
Servo saver position: ?
Eccentric upper arm position: Front holders upper hole / Rear Holder lower hole
One way diff
Springs: White short
Shock oil: 30WT
Damping: 2 holes closed
Shock top position: Outer hole, original T1 tower
Shock bottom position: Outer hole
Ride height: 5 mm
Toe in/out: 1 out
Droop setting: 2mm
Rear:
Camber: 1,5 neg.
Kickup: 0, arms raised to top position
Wheelbase: middle (dont remember how many mms)
One way centre layshaft tightened 100%
Springs: Yellow (Serpent)
Shock oil: 30WT
Damping: 1 hole closed
Camber link: Long and high on rear hub.
Ride height: 6 mm
Droop setting: 4mm
Balancing weights:
50g in the middle of chassis, between electronics
10g on each side of chassis rear
Rubber tires, Sorex 36
Protoform Stratus body, std wing
@rough512: I have not looked into the reactive caster. Can you explain?
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Savx
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 05-27-2004, 05:13 AM   #7160
Sleighty's Avatar
Default Parts???????
Hey Guys,
Can somebody tell me where i can buy - XR-302000 (Alu suspension adjustable bulkheads + free tool set) from? anywhere which has an online website would be nice. I cant find this part anywhere
cheers
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 05-27-2004, 01:03 PM   #7161
JDXray's Avatar
Send a message via AIM to JDXray
www.ashfordhobby.com
www.serpent-usa.com
JDXray is offline   Reply With Quote
Old 05-27-2004, 02:47 PM   #7162
anyone got a x ray t1 for sale
HEWITT is offline   Reply With Quote
Old 05-27-2004, 02:51 PM   #7163
JDXray's Avatar
i got the main chassis, bulkheads, and extras. PM Me.
Old 05-28-2004, 01:16 AM   #7164
evaa's Avatar
i beleive even a strong hit wont really shatter the plastic shock bodies, was runnin last night, and coz of set up problems, my car was fishtailing all over, had several hits, rather bad ones, especially in the rea, with no damage being brought upon the shocks.
hence, i think in terms of durability, those plastic shocks are unquestionably tough.
Old 05-28-2004, 02:12 AM   #7165
Yeah, right.
Theywill break if you are hit, seen it happen lots of times. I think you are just lucky so far.
Old 05-28-2004, 02:23 AM   #7166
evaa's Avatar
Yeah, right.
sure am, glad it hasnt hapened to me, have you replaced your plastic shock bodies with the alum ones? did you notice any change?
Old 05-28-2004, 02:34 AM   #7167
4 weeks ago I raced at a clubrace, my car was standing on the grid when a car hit my rear at full speed.(the idiot was doing a warmup lap).
After the start I noticed a rear shock had come loose and I stopped after 1 lap.
In the 2nd final the same thing happened with another car. That car was using the composite shock bodies and one broke.
I don't know if you will notice a difference. I am just finishing my 2nd car which will have composite shocks so maybe I will notice a difference. May not.
(I plan to take the 2 alu. shocks off the front of my first car and put them on the rear of the second car)
Old 05-28-2004, 03:09 AM   #7168
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
evaa.
Get the Alu shock housing.
Its worth the money and less pain during race day.
Furthermore, its easier to screw in the cap and the adjuster.
It wont be so easy to strip the thread on the shock body too.
As for performance, cant see or feel any.
AdR|aN is offline   Reply With Quote
Old 05-28-2004, 05:22 AM   #7169
Yo guys check this out!
X-ray is testing a new chassisplate!
840918001 is offline   Reply With Quote
Old 05-28-2004, 05:22 AM   #7170
And another picture of the new chassisplate.
