Kyosho V-ONE RRR EVO 2
#1396
broken rr hub
Hi guyz,
I just broke my rear hub when i had a bad crash a week ago, any fix for this or countermeasure so in the future it wont happen again ( of course- beside from crashing again). I already used long screw (3x18 f/h screw) but to no luck it just broke off.
(item#3 on page 21) where 3x18 f/h screw have to be fixed
Thanks in advance.
Thanks in advance.
#1397
Hi guyz,
Thanks in advance.
Thanks in advance.
#1398
Hi guyz,
Thanks in advance.
Thanks in advance.
If you cant find it then what I have done in the past is to use the washer off the old car that is used to sperate the rear axle for 2 degree wheels.
You will find that it slides straight over the plastic on the top of the hub and will offer extra support in the event of a crash. Hope you know what I mean.
I will try and take a pic tonight if you dont.
#1399
#1400
Hey Chaya. Where did it break? On the top where the screw goes in? If so the other option other than the longer screws is to use an aftermarket part that slots over the plastic. I cant remember who makes it. I think it was K-Factory.
Yup Barg, that is the exact point where it broke off
Anyway ill try your suggestion. Ill try to look for some washer and have it cement on that portion just to give extra support as you where saying.
#1402
#1403
Hi; Scott
What are the differences between the various fuel tanks - VZ207, VZ207B and VZ207C. My tank has a leak ( VZ207C) . I have two of the VZ207 tanks (new spares from an eariler car) and will be attending the ROAR 1/10 Nationals. Do you think I should use the new spares or get another VZ207C tank?
#1404
I've got a couple of G4 parts on my Evo 2 already and they fit pretty well (rear brake rotor, brake pads and front cvd's) but do you think this will fit?
http://www.redrc.net/2009/08/k-factory-g4rs-front-solid-one-way-axles/
#1405
Hi; Scott
#1407
Can you get harder springs for the 2d clutch system other than the one that comes in the kit.
stock setup up is .3 of thread showing on the nut . i was in about .98 mm and the clutch felt so good very snappy and responsive. does going tighter on the clutch nut effect the run time. and should i gear the engine a bit higher for the loss of initial rpm from a tighter nut setting .
cheers
alex
cheers
alex
#1408
cheers
alex
cheers
alex
#1409
rx battery pack
could someone tell me would any 1400 r 1600 brand 5 cell pack work in my car
#1410
Hi guyz,
Thanks in advance.
Thanks in advance.
