Old 08-16-2009, 10:09 PM   #1396
Chaya's Avatar
Default broken rr hub
Hi guyz,
I just broke my rear hub when i had a bad crash a week ago, any fix for this or countermeasure so in the future it wont happen again ( of course- beside from crashing again). I already used long screw (3x18 f/h screw) but to no luck it just broke off.
(item#3 on page 21) where 3x18 f/h screw have to be fixed
Thanks in advance.
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 08-16-2009, 11:11 PM   #1397
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by Chaya View Post
Hi guyz,
Thanks in advance.
Sometimes parts break in a hard crash.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-16-2009, 11:22 PM   #1398
barg's Avatar
Send a message via Yahoo to barg
Hi guyz,
Thanks in advance.
Hey Chaya. Where did it break? On the top where the screw goes in? If so the other option other than the longer screws is to use an aftermarket part that slots over the plastic. I cant remember who makes it. I think it was K-Factory.
If you cant find it then what I have done in the past is to use the washer off the old car that is used to sperate the rear axle for 2 degree wheels.
You will find that it slides straight over the plastic on the top of the hub and will offer extra support in the event of a crash. Hope you know what I mean.
I will try and take a pic tonight if you dont.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 08-16-2009, 11:24 PM   #1399
barg's Avatar
Originally Posted by Scott Fisher View Post
I use the pivot ball and the ball bearing supported piece.
Hey Scott,
Does running the ball bearing peice remove a bit of the slop on the top arm?
Does the plastic piece come in the kit or is it an option part?
www.nswrcrcc.com
Old 08-16-2009, 11:36 PM   #1400
Chaya's Avatar
Yup Barg, that is the exact point where it broke off
Anyway ill try your suggestion. Ill try to look for some washer and have it cement on that portion just to give extra support as you where saying.
Old 08-17-2009, 12:03 AM   #1401
Hey Scott,
Yes, it does remove a bit of the slop on that end. I can't say for certain with the EVO2, but it did come with my EVO WC kit. My guess is that it came with the EVO2 kit as well, but I don't know for certain.
Old 08-17-2009, 06:00 AM   #1402
Suspended
Yes, it comes in the EVO2 kit as well.
King Nitro is offline   Reply With Quote
Old 08-17-2009, 06:51 AM   #1403
Hi; Scott
What are the differences between the various fuel tanks - VZ207, VZ207B and VZ207C. My tank has a leak ( VZ207C) . I have two of the VZ207 tanks (new spares from an eariler car) and will be attending the ROAR 1/10 Nationals. Do you think I should use the new spares or get another VZ207C tank?
andy4 is offline   Reply With Quote
Old 08-17-2009, 07:42 AM   #1404
YmeBP's Avatar
Trader Rating: 32 (100%+)
I've got a couple of G4 parts on my Evo 2 already and they fit pretty well (rear brake rotor, brake pads and front cvd's) but do you think this will fit?
http://www.redrc.net/2009/08/k-factory-g4rs-front-solid-one-way-axles/
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-17-2009, 10:09 AM   #1405
Originally Posted by andy4 View Post
Hi; Scott
I don't know the differences. I remember when the EVO 2 car came out I asked what the difference was between the 207B and the 207C and the initial answer was "I didn't know there was a new tank." I remember than Ron and I both compared the tanks and we couldn't visually see a difference. I am going to send out an email asking about the differences but my guess is that there is some difference(s) in the cap/seal and or the fuel pickup.
Old 08-17-2009, 02:00 PM   #1406
I asked about the tanks and the answer I got was " they have revised the lids to make them stronger".
Old 08-17-2009, 04:27 PM   #1407
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Can you get harder springs for the 2d clutch system other than the one that comes in the kit.
stock setup up is .3 of thread showing on the nut . i was in about .98 mm and the clutch felt so good very snappy and responsive. does going tighter on the clutch nut effect the run time. and should i gear the engine a bit higher for the loss of initial rpm from a tighter nut setting .
cheers
alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 08-17-2009, 05:00 PM   #1408
cheers
alex
You can try using the Orion spring.
Old 08-17-2009, 05:43 PM   #1409
Default rx battery pack
could someone tell me would any 1400 r 1600 brand 5 cell pack work in my car
thanks to manney Vallejo rc
locman40 is offline   Reply With Quote
Old 08-17-2009, 06:19 PM   #1410
GMartinez's Avatar
Trader Rating: 85 (100%+)
Hi guyz,
Thanks in advance.
www.rcmushroom has a rear hub protector that comes with different offset it is made by 3racing
GMartinez is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
