Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 01-14-2013, 11:34 PM
  #4306
Originally Posted by MrHistory
Be sure to use a shorter ball end on your rear shocks with the RB5 arms. I first had the long ones on and the spring adjuster was backed out all the way. I use the short ball end. Have not tried the medium.
Gitsum is offline
Old 01-15-2013, 12:54 AM
  #4307
Lonestar's Avatar
Trader Rating: 14 (100%+)
Hey Guys
I lost the front metal arm brace saturday during the race... the setscrews that hold the front arm axles backed out the axles moved back and voila the brace flew off, never to be found again
as I was browsing amain for replacement and I typed "RB6 brace" or sthing in the "search" box, I came upon all these 4 parts.
http://www.amainhobbies.com/product_...Brace-Gunmetal
http://www.amainhobbies.com/product_...unmetal-RB5-WC
http://www.amainhobbies.com/product_...inge-Pin-Brace
http://www.amainhobbies.com/product_...n-Plate-Type-B
The instructions reference UM720... the last link - note it's the more expensive one.... Are the first 3 really a direct fit on the RB6? Why so many references? Are we being fooled?
Other than that, the car works really, really well. I finally got the diff sorted out after a good rebuild, but that bit is way more sensitive than my B4's....
Cheers
Paul
PS: Brandon, Schuey received???
Lonestar is offline
Old 01-15-2013, 01:13 AM
  #4308
mdowney's Avatar
Trader Rating: 21 (100%+)
UM720 is the correct part. The other two are different widths and were made for the RB5 SP2 and RB5 SP2 WC kits. If you use the other braces you have to run a different suspension block and front arms.
Beware that this part bends easily. I'm not 100% sure but I think Kyosho may be revising the part soon to make it more sturdy.
mdowney is offline
Old 01-15-2013, 01:21 AM
  #4309
K_King's Avatar
Trader Rating: 47 (100%+)
Yeah I think they are making it strong which is nice, it bends way too easy as thick as it is.
K_King is offline
Old 01-15-2013, 01:22 AM
  #4310
Just1More's Avatar
Trader Rating: 11 (100%+)
KYOUMW519GM is too wide for the RB6, KYOUM720 is the correct part number for that piece!
Just1More is offline
  #4311
Lonestar's Avatar
Thank you both
My next run is end-feb (yup... I don't get much wheel time ) - any idea if the revised bit would be released before then?
thank you!
Paul
Edit- thanks to you three, Just1more posted right at the same time as me... not sure about the part now tho :P
Lonestar is offline
Old 01-15-2013, 01:26 AM
  #4312
mdowney's Avatar
Originally Posted by Turbo911
What are the part numbers for the shock ends. Short, medium and long.
S = W5015
M = 97038
L = LA43
mdowney is offline
Old 01-15-2013, 01:29 AM
  #4313
mdowney's Avatar
Originally Posted by Just1More
KYOUMW519GM is the exact same, perfect fit. I bought one as a spare and have test fitted it on my RB6, so it's a guarantee.(I checked my Amain history to verify part number). Good luck
You might want to examine those very closely. My understanding is that they are just slightly different in size. You have to put them back to back and run a suspension rod through them to be sure.
mdowney is offline
Old 01-15-2013, 01:37 AM
  #4314
Just1More's Avatar
You're right, it's too long by a few mm's. KYOUM720 must be the right part number then. Thanks for letting me know, i'll edit my post(can you do the same?) to reflect the right number
Old 01-15-2013, 03:05 AM
  #4315
Originally Posted by mdowney
S = W5015
M = 97038
L = LA43
Thank you,
Turbo
Turbo911 is offline
Old 01-15-2013, 03:14 AM
  #4316
Andy63's Avatar
Kyosho Rb6 1st and 2nd at Petit race in norway this weekend! Congrats Christoffer Svensson for 2nd and David Ronnefalk for 1st!
Andy63 is offline
Old 01-15-2013, 08:02 AM
  #4317
Cpt.America's Avatar
Trader Rating: 52 (100%+)
hah!! Hey Paul! Not yet, amigo! I missed a registered mail delivery yesterday and have to go to the post office today to pick it up, but i DO have a couple packages on the way... not sure if it's yours. Im really really excited though!
Cpt.America is offline
Old 01-15-2013, 08:13 AM
  #4318
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Brandon, thanks for all your work so far! Looks good.
Posvar is offline
Old 01-15-2013, 08:34 AM
  #4319
Maybe this has already been posted, but i could not find it. What effect does running the castor block in the "in" or "out" position have.
Dale.0 is offline
Old 01-15-2013, 08:39 AM
  #4320
it either widens or shortens the front track width. Shorter track width for more steering, wider for less.
