TLR 22SCT Thread (Check First Page for FAQ & INFO)
#6691
Thought I would chime in on the ball diff issue. For those that are having issues with broken bolts, try installing the diff in the opposite direction as instructed. Associated diffs adjust from the same side as the slipper for a reason. It will not over tighten as you drive. I installed it this way from the build and have not had a single issue with stock parts. I found it strange that the instructions say to install it with adjustment on the left side.
#6692
we put the diff screw on the left for the simplicity of adjusting it (with the diff tool, its pretty easy). I need to look at my truck, but i dont think there is enough room to fit the diff tool in between the spur gear cover and the rear shock tower.
#6698
How do you stop the rear end from "bucking" up when going through a section with discs off set? Would you run larger hole pistons or go with different springs? This is on carpet and I'm pretty sure it is the Frank Root setup.
#6702
Hello gentlemen,
I just acquired a 22sct roller, which I should have this coming week. It'll be my first SCT, so I'm trying to get a grasp on the basics. I'm currently trying to understand which bodies will fit the truck. ProLine lists the "Flo-Tek Chevy Silverado" as fitting, is that a good choice? I'd like to reduce the parachute effect as much as I can, but also have a body that will take the abuse of a novice driver.
I'd appreciate any recommendations, thanks!
#6703
is the truck grounding out? if it is, go thicker on shock fluid, or to the next step smaller piston.
Caspers set up may work better on carpet hen root's. but I dont know, ive never run on carpet, except my living room.
#6704
Hello gentlemen,
but I checked ProLines website, and you're right, its saying that the tundra, silverado 1500, and militia bodies fit this truck. interesting.
the proline bodies are thicker them the JC, and my year old Flo Tek body for my XXX-SCT has no a single crack (after some hard crashes too) and my tlr hiflow is held together with aluminum tape and shoegoo.
for stock racing, you really need the light weight body. for modified, you'd be fine with the proline, but the JC and tlr bodies are lighter. the proline bodies will do you best if you are a novice or for bashing.
#6705
I must say Frank these 22 diffs are difficult.......I have been racing for 20 years, I could build a xxx series diff in my sleep and make them last for a very long time, these 22 diffs have be baffled to the point I am thinking of throwing the gear diff in and being done with it, I have watched the tlr video dozens of times, I have even(i hate to say this) tried the associated diff screw thrust bearing and spring. That did make it a little better but man it gets frustrating when your diff goes out after only a couple race days. I dont even run mean motors, 13.5 blinky in 22b, 22t and 22sct, the 22b diff is holding fairly well but the other two .......sheesh.
1. The rings weren't sanded. At least, it didn't look like it. If they were, they weren't always perfectly smooth.
2. The thrust bearing washers wore out really fast and often disintegrated after a month.
3. The stock diff balls were not the best either and could be flat spotted easily.
You can fix these things pretty easily:
1. Sand your rings with 180 grit paper and then finish with 400 grit paper in a figure 8 pattern. Make sure the entire ring is sanded before you stop. Putting the ring on a used female out drive makes this easier.
2. Use the Associated thrust washers and thrust balls.
3. Use the TLR tungsten carbide diff balls.
As an alternative to that, you can buy the b-fast 22 kit. The b-fast rings come pre-sanded, and their thrust washers and balls are of high quality.
I've built diffs with steps 1-3 and with the b-fast kit. Both will work well, and when done correctly, they should last you a long time.
