Team Orion 3200mAh Race Spec LiPo
#1291
Originally Posted by harkonen
There isn't any reason I can't run the 3200 pack with a regular ESC (QC2) and a 19T brushed motor right? Everyone I've seen that has run the 3200 battery has used Brushless as well, so I wasn't sure.
both work flawlessly! enjoy.
#1292
Originally Posted by Hebiki
yes you're safe. ive run my 3200s with a VFS-1 and VFS-2000 along with a Checkpoint 19T and Reedy Quad Mag 19T...and the Novak 10.5 brushless
Back on topic... I'll be testing out the 3200 pack for the first time this weekend. I'll do some comparison runs vs 4200 packs. Both our local tracks just legalized lipos as long as they meet 1525g weight rule. I'll be testing them with the 13.5pro.
#1293
Jimmy, didn't you read the fine print? Lip is approved for everyone but you at 1525, you have to run 1625
#1294
Damn!! 1625g for me? Does that mean I get to run the 10.5 while everyone runs the 13.5??
#1295
Originally Posted by KilRuf
Where are you gearing your 10.5? I have one and raced it with some mod guys on a mid sized asphalt track. But had no clue how to gear it. I normally gear my 13.5pro at 5.0 final just to give you an idea. I only dropped 1 tooth on the 10.5pro and it was HOT to the touch after the qualifier. Just trying to get a general idea.
#1296
Cool... thanks... I'm not that far off then.
#1297
No Jimmy, you have to run the 17.5 , with all that maybe the rest of us can catch up, well maybe I can get within a lap of you anyway
#1298
Originally Posted by MrBlack
We make small 1500mah LiPo from our Avionics line that some have successfully used to make 3000mAh 7.4V saddle packs with and we have had some make other options as well.
http://www.teamorion-avionics.com/Ba...Li-Po/1500mAh+
With LiPo you have 2 choices in our range 3.7V (1S or 1 cell)[1C is a different rating] or 7.4v (2S 2 cell). yes I know their is the rumored 5V cells but they are just not stable amongst other issues. The problem with tooling a saddle pack case is that to make the case fit the exact size of a 3x3 or 2x2 you sacrifice a great deal of usable space and the tooling needed and R&D time is costly for such a small percentage of users (I personally wish 1:12 was more popular as it is such a cool class) so the investment is a far larger gamble then with other application that we are looking into. Though we do constantly revisit the idea of a saddle pack and have a design finished in place we still await the proper time to green light it.
i run a gen x so i need a stick
i guess thats even more to think about.
guess we will just suffer with sub c
suffer i say
#1300
You have to take out the battery braces. And you either have to grind away alitte of the rear layshaft bulk head, or cut a slot into the battery to fit. I just ground down alittle of the bulk head. Plus I ground down a few of the braces to help keep the battery from moving around.
#1301
so what your saying is it dose not fit in a t2
so ill get a losi.
so ill get a losi.
#1302
Well, ran the 3200 today with the 13.5pro in my '007. I would have to say that it's maybe 1 or 2 tenths slower than when I ran my 4200s. Same car. Same balance. Same weight. Same ratio. Same setup. Etc. It was nice though only having to run 1 pack the whole day. Only took around 35~40 minutes between rounds to repeak the pack. I had a backup 3200 pack. But never used it. Not bad so far. Will do some more testing later on. Sucky part was trying to find where to add 248g or so to the battery side to make the 1525g rule and keep the car balanced left to right! I'll have to take a pic...
#1303
The 3200 does fit the t2 '007'. The most secure way I found was to to remove the 2 centre plastic holders and file the radius off the corner ones so the 3200 sits lower and mor secure.
#1304
Adding weight is the easy part! I race a no-weight limit class and I'm trying to not add weight. The pack sits sideways in my chassis so it balances out no problem. However I'm struggling to get the car to roll properly and it's TOUGH! It's cornering sh*tty....
#1305
Originally Posted by wallyedmonds
i see but i dont need saddles
suffer i say
suffer i say
