Old 05-16-2007, 07:22 PM   #1291
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by harkonen
There isn't any reason I can't run the 3200 pack with a regular ESC (QC2) and a 19T brushed motor right? Everyone I've seen that has run the 3200 battery has used Brushless as well, so I wasn't sure.
yes you're safe. ive run my 3200s with a VFS-1 and VFS-2000 along with a Checkpoint 19T and Reedy Quad Mag 19T...and the Novak 10.5 brushless
both work flawlessly! enjoy.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-16-2007, 08:36 PM   #1292
JimmyMac's Avatar
Where are you gearing your 10.5? I have one and raced it with some mod guys on a mid sized asphalt track. But had no clue how to gear it. I normally gear my 13.5pro at 5.0 final just to give you an idea. I only dropped 1 tooth on the 10.5pro and it was HOT to the touch after the qualifier. Just trying to get a general idea.
Back on topic... I'll be testing out the 3200 pack for the first time this weekend. I'll do some comparison runs vs 4200 packs. Both our local tracks just legalized lipos as long as they meet 1525g weight rule. I'll be testing them with the 13.5pro.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-16-2007, 08:44 PM   #1293
Jimmy, didn't you read the fine print? Lip is approved for everyone but you at 1525, you have to run 1625
tarheelquality is offline   Reply With Quote
Old 05-16-2007, 09:02 PM   #1294
JimmyMac's Avatar
Damn!! 1625g for me? Does that mean I get to run the 10.5 while everyone runs the 13.5??
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-16-2007, 09:18 PM   #1295
Hebiki's Avatar
at the Tamiya track fun race.. i was at 5.5 and went up a tooth each round and finally settled around 5.25-5.3 FDR
Hebiki Design Works
Old 05-16-2007, 10:29 PM   #1296
JimmyMac's Avatar
Cool... thanks... I'm not that far off then.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-17-2007, 04:45 AM   #1297
No Jimmy, you have to run the 17.5 , with all that maybe the rest of us can catch up, well maybe I can get within a lap of you anyway
Old 05-18-2007, 09:30 PM   #1298
wallyedmonds's Avatar
Originally Posted by MrBlack
We make small 1500mah LiPo from our Avionics line that some have successfully used to make 3000mAh 7.4V saddle packs with and we have had some make other options as well.
http://www.teamorion-avionics.com/Ba...Li-Po/1500mAh+
With LiPo you have 2 choices in our range 3.7V (1S or 1 cell)[1C is a different rating] or 7.4v (2S 2 cell). yes I know their is the rumored 5V cells but they are just not stable amongst other issues. The problem with tooling a saddle pack case is that to make the case fit the exact size of a 3x3 or 2x2 you sacrifice a great deal of usable space and the tooling needed and R&D time is costly for such a small percentage of users (I personally wish 1:12 was more popular as it is such a cool class) so the investment is a far larger gamble then with other application that we are looking into. Though we do constantly revisit the idea of a saddle pack and have a design finished in place we still await the proper time to green light it.
i see but i dont need saddles
i run a gen x so i need a stick
i guess thats even more to think about.
guess we will just suffer with sub c
suffer i say
wallyedmonds is offline   Reply With Quote
Old 05-18-2007, 10:43 PM   #1299
SammyZ's Avatar
Trader Rating: 138 (100%+)
does the orion 3200 fit in the T2 '007?
SammyZ is offline   Reply With Quote
Old 05-18-2007, 10:57 PM   #1300
JimmyMac's Avatar
You have to take out the battery braces. And you either have to grind away alitte of the rear layshaft bulk head, or cut a slot into the battery to fit. I just ground down alittle of the bulk head. Plus I ground down a few of the braces to help keep the battery from moving around.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-19-2007, 06:37 AM   #1301
so what your saying is it dose not fit in a t2
so ill get a losi.
Old 05-19-2007, 09:58 PM   #1302
JimmyMac's Avatar
Well, ran the 3200 today with the 13.5pro in my '007. I would have to say that it's maybe 1 or 2 tenths slower than when I ran my 4200s. Same car. Same balance. Same weight. Same ratio. Same setup. Etc. It was nice though only having to run 1 pack the whole day. Only took around 35~40 minutes between rounds to repeak the pack. I had a backup 3200 pack. But never used it. Not bad so far. Will do some more testing later on. Sucky part was trying to find where to add 248g or so to the battery side to make the 1525g rule and keep the car balanced left to right! I'll have to take a pic...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-20-2007, 11:57 AM   #1303
The 3200 does fit the t2 '007'. The most secure way I found was to to remove the 2 centre plastic holders and file the radius off the corner ones so the 3200 sits lower and mor secure.
Steve B is offline   Reply With Quote
Old 05-22-2007, 12:44 PM   #1304
TEM
TEM's Avatar
Adding weight is the easy part! I race a no-weight limit class and I'm trying to not add weight. The pack sits sideways in my chassis so it balances out no problem. However I'm struggling to get the car to roll properly and it's TOUGH! It's cornering sh*tty....
TEM is offline   Reply With Quote
Old 05-22-2007, 12:56 PM   #1305
MrBlack's Avatar
suffer i say
If you are running a 6 cell stick pack application then the 3200 should fit?
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
