Like Tree34Likes
Schumacher Mi5
Old 11-17-2013, 05:42 AM
  #1636
Originally Posted by snuvet75
That's interesting because I thought front spool gives more entry steering..
The idea of a front spool is to give better traction out of the corner by locking the front axles together, the downside is that it kills turn in steering. Not a problem on large asphalt tracks as the reduced steering helps stabilise the car under braking.
Spools came about because we used to use front one ways as the extra traction out of the corners of the locked front axle was faster, but rear wheel only braking made the cars very unstable and front one ways were starting to be banned from some big meetings. The spool gave you that extra traction out of the corners, and the chassis were redesigned to compensate for the lack of entry steering from the spool.
In theory a front diff will always be faster on tight high grip carpet tracks, but with chassis design and setup based around the front spool it's not always the case.
terry.sc is offline
Old 11-17-2013, 01:01 PM
  #1637
HappyHippo's Avatar
Trader Rating: 12 (100%+)
Try this setup... this track had monstergrip, and cars did tractionroll...
http://hofaaa.files.wordpress.com/20..._hrotovice.pdf
This setups is awsome with sorex 28, car is a litle more "egdy" with spool, you can also try Yokomo yellow spring in the rear...
HappyHippo is offline
Old 11-18-2013, 04:08 AM
  #1638
subzero2k's Avatar
Hi,
what do you need the small carbon parts for? They come with the stiff chassis.
Maybe to connect the left and rigth pivot balls in the wishobones and make the alloy screws last longer?
http://www.redrc.net/2013/09/schumac...ssis-ti-balls/
Greetings
subzero2k is offline
Old 11-18-2013, 04:25 AM
  #1639
TryHard's Avatar
Originally Posted by subzero2k
Hi,
Greetings
They do two things. Help to stop screws pulling through the chassis in a big accident, and also stiffen the rear of the car up and help it rotate through the corners better.
Alternatively, you can leave them off and use alloy screws in the back of the car as well as the front.
HiH
Ed
TryHard is offline
Old 11-18-2013, 11:32 AM
  #1640
I crash tested my Mi5 pretty decently the last couple race nights (really bad driving on my part - not enough sleep). Nothing broke or tweaked
DavidNERODease is offline
Old 11-21-2013, 07:15 PM
  #1641
silvalis's Avatar
Trader Rating: 29 (100%+)
So Hara was driving an Mi5 on the weekend...
silvalis is offline
Old 11-21-2013, 07:18 PM
  #1642
snuvet75's Avatar
Trader Rating: 16 (94%+)
Where? How did you find it out? Is he thinking of driving for Schumacher?
snuvet75 is offline
Old 11-21-2013, 07:19 PM
  #1643
silvalis's Avatar
http://www.redrc.net/2013/11/atsushi...-opening-race/
I doubt it. He seems to be having a go at every car in every class across the market.
silvalis is offline
  #1644
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
whoops, got to it before i did
Dan is offline
Old 11-22-2013, 04:08 PM
  #1645
Trader Rating: 72 (100%+)
If interested in a brand new Mi5 for an excellent price, please check below link.
http://www.rctech.net/forum/r-c-item...never-run.html
waswadener is offline
Old 11-23-2013, 11:01 AM
  #1646
I have two Mi5 cars, and both of the have leaking diffs. It seems to come out from where the two parts are assembly togehter, and comming out where the two o-rings are located. Does anyone have a fix for this ?
Shock Tower is offline
Old 11-23-2013, 02:57 PM
  #1647
chiefj48's Avatar
Use three o-rings and no more leaks
chiefj48 is offline
Old 11-23-2013, 07:22 PM
  #1648
DiscountRCStore's Avatar
Pm or email me, we have them available by themselves ..
+1,.. that's the ticket!
..p
DiscountRCStore is offline
Old 11-23-2013, 11:39 PM
  #1649
snuvet75's Avatar
Pressure is too high. Too much oil or air bubble. Let it sit till all air bubbles are gone before you close the diff case. Fill the oil only till the shafts meet the level of oil. If not, ask anybody else LOL
snuvet75 is offline
Old 11-25-2013, 09:36 AM
  #1650
haywood's Avatar
Trader Rating: 49 (100%+)
Default Mi5
Had a great day club racing with the Mi5! Car is on pace and has been very durable. Finished 3rd after starting 9th in the A! 3 orings solved the leaking rear diff. I'm running the shocks with the cut shafts and Yokomo Springs. (Emulsion style)
haywood is offline
