HPI Cup Racer 1M >
HPI Cup Racer 1M
Like Tree2Likes
HPI Cup Racer 1M
Old 05-17-2011, 11:17 AM
  #2386
How about if the bottom happens to hit the ground, does it wreck the whole car, or just leave a mark, and the car keeps on going?
I was thinking of rally, since I'm not sure whether am I going to like touring, since there are not so many places to drive.
Chillay is offline
Old 05-17-2011, 11:20 AM
  #2387
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by superspeed
The old school BMW body from HPI for the cup racer looks pretty cool. It has similar styling as the Alfa Romeo Guilia GTA.
That's a historic racing rivalry, Alfa Romeo Giulia GTA and BMW 2002 tii. I think it would be awesome to organise a race with only Alfa and BMW on the track battling it out.
Raman is offline
Old 05-17-2011, 11:22 AM
  #2388
Raman's Avatar
It won't wreck the car. The bottom of the chassis will eventually get scratched or marked. Excessive scratched on the front and rear near gear box are actually signs that you need to raise the ride height for better traction.
Raman is offline
Old 05-17-2011, 11:27 AM
  #2389
superspeed's Avatar
Default To Raman
How did the Alpine do back in the old days? Was it a competitor for Alfa & BMW?
superspeed is offline
Old 05-17-2011, 11:42 AM
  #2390
For the motor I was thinking Ez-run 4000kv, on 2s or 3s.
I wouldn't want to make it a missile on the first runs, i can upgrade if the ~20-30mph isn't enough
How about the weak links, not so plastic axle cups are a must? anything else?
Chillay is offline
Old 05-17-2011, 12:23 PM
  #2391
Raman's Avatar
The alpine raced mainly as a rallye car. Although they did hold hill climb races which may have pegged it against the Alfa and BMWs
The rivalry back then (ETCC) was mainly Alfa, BMW, and Ford (capri i think) in division 2. The 911T (4 cyl) may have been in there as well.
Raman is offline
Old 05-17-2011, 01:00 PM
  #2392
The center front plastic drive cup is a weak link. I would replace it with an Exotek alloy one. The orange front lower inner pin holder can bend if the front tires/suspension get hit. I would double it up.
Sydewynder is offline
Old 05-17-2011, 01:47 PM
  #2393
Raman's Avatar
+1.. I didnt finish 2 races because of this!
These m cars need a foam bumper that reaches out to the wheels.. Like other cars.
Raman is offline
Old 05-18-2011, 04:13 PM
  #2394
im borrowing a 510 cup racer from a friend and now i want one lol
bonvo is offline
Old 05-18-2011, 05:43 PM
  #2395
Saint Bastia's Avatar
If you have the nut that's on the bottom set flush to the end of the screw you should not have problems with limited suspension travel though it does look like there's very little freedom of movement. This rod is acts as a steering knuckle stopper only. You can use a shorter threaded screw and nut so it doesn't pass through both upper and lower arms. There's a couple of pics on this thread. Look for MikeR's posts.
Thks for the reply Sydewynder,
Yes, on my CR the Z661 nut is flush with the Z419 screw. Suspension arm travel is very stiff and less than 5mm. I couldn't find MikeR's posts ?
ps here's a pic taken in the ACT back in the 70's...it's for Alfa Milano fans...the car is my fathers and is a 58 build 4 with 5 speed, twin cam, twin Solex double barrel 48mm carbs...paint is white with red interior...instrument cluster has a ton of elegantly placed gauges and switches...from memory olio temp and pressure, batt volt, benzene, aqua temp, tach and the mandatory speedo...drum brakes as disc came out in 59...very few were made...something like less than 2000...body was designed by the late Pininfarina...oh yeah...nearly forgot to tell it's a removable hardtop as well.
Saint Bastia is offline
Old 05-18-2011, 05:54 PM
  #2396
Raman's Avatar
Oh man do I love those. The shop I service my Alfa has 2 of those.. One 2000 and the other the 2600. Those were the last of the Alfa inline 6s.
Raman is offline
Old 05-18-2011, 05:57 PM
  #2397
Raman's Avatar
Raman is offline
Old 05-18-2011, 06:02 PM
  #2398
Raman's Avatar
Me and the alfa gang on Malibu Canyon
First one is mine a 1969, followed by a 1974 and a 1973
Raman is offline
Old 05-18-2011, 06:23 PM
  #2399
Nice GTVs! Are you on the alfabb forums?
Old 05-18-2011, 06:56 PM
  #2400
Raman's Avatar
Yep, same user name on Alfa BB
Raman is offline
