Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 12-14-2007, 10:50 AM
  #9691
Trader Rating: 28 (100%+)
If I run across a set I may pick them up and give them a try. The ones you purchased were for the Kyosho, or the G4?
Scott Fisher is offline
Old 12-14-2007, 11:24 AM
  #9692
Scott, it's the same pad for both of them, part # K1498
http://www.kfactoryracing.com/produc...1498&pageNum=4
from that web site:
Suitable for Many types of car:
Real Racing Brake Pad is not only can be installed for G4, but also for Kyosho series cars.
Kyosho V1 series R/ RR EVO/ RRR/ S
Kyosho FW05 Series R/ RR/ S/ T
Kyosho MP series MP7.5/ 777
Ramiel is offline
Old 12-14-2007, 04:20 PM
  #9693
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Wink
I plan to try out the kfactory disc & pads myself.
Ivan Dickson is offline
Old 12-19-2007, 07:25 PM
  #9694
Grub Screw's Avatar
Default Setting Data
Hi does anyone have the setting data sheet in English, the one with the rollouts, I can download for a RRR EVO.
I have one but it's in Japanese as I bought the car from RC Champ in Japan (local hobby stores too expensive here in OZ). I have tried all the Kyosho website but can only find setup sheets.
Grub Screw is offline
Old 12-20-2007, 02:25 AM
  #9695
pramac's Avatar
Is this what your after? I forget where I got it from, it looks like a scan to be honest.
Gavin.
File Type: pdf
pramac is offline
Old 12-20-2007, 09:28 AM
  #9696
You won't regret it
Ramiel is offline
Old 12-20-2007, 11:15 AM
  #9697
Questions??
Does anyone know were I can purchase Kfactory brake pads from? I found the disc I just need the pads.
Old 12-20-2007, 11:36 AM
  #9698
Team Kamikaze's Avatar
I do!
Team Kamikaze is offline
Old 12-20-2007, 01:16 PM
  #9699
Thumbs up
Originally Posted by Team Kamikaze
I do!
Thanks Sam I will be calling you soon.....
Old 12-20-2007, 02:59 PM
  #9700
KyoshoKid's Avatar
Default Kawahara brake disk
I have just put in the kawahara brake disk and had to increase the width between the stock pads to 8mm because its twice as thick as the stock disk brake, which meant screwing out the 15mm screws a fair bit.
My concern is that the screws may be out too far even though the disk pads seem to be sturdy.
Has anyone has any problems with the kawahara brake disk and stock pads falling out during racing?
Should I use longer screws?
Can you get 20mm screws?
KyoshoKid is offline
Old 12-20-2007, 11:52 PM
  #9701
Grub Screw's Avatar
Gavin.
That is it thanks a lot Gavin
Old 12-21-2007, 04:02 PM
  #9702
tony montana's Avatar
Trader Rating: 76 (100%+)
any rumors of a new 1/10 sedan from kyosho any time soon or will my rrr wce still be current for next year
tony montana is offline
Old 12-21-2007, 08:09 PM
  #9703
maskedrider's Avatar
Merry Christmas and Happy New Year to all Kyosho RRR driver here
maskedrider is offline
Old 12-23-2007, 12:18 PM
  #9704
ok guys, what mm offset do the rear wheels need to be for the rrr wce? Im getting ready to place a order, also what do you guys suggest to make the car more durable.
Old 12-23-2007, 12:27 PM
  #9705
also does kyosho make a one way/ soild front all in one
