Kyosho Ultima RB6 & RB6.6 Car Thread
#2567
I concur with what was posted previously... the alu steering rack is a must, but the plastic arms/swivels should be just fine. Their lateral strength should be more than adequate. I doubt you will ever see one break. Run whichever of the two (alu or plastic) is lighter. The last thing you need is more weight on this car.
#2569
Just curious: Is anyone with the stock rack still breaking theirs? I ran mine half a dozen times in mod (now back to stock) and the original plastic rack is still fine.
What were you hitting in order to break it? And are these spare plastic racks and exotek rack I bought going to sit in a box looking sad like all of the other K spares I bought for my RB5 and never used...
#2570
Avid Triad Slipper System
I finally got the chance to test the new Avid Triad slipper & top shaft at WCRC. Between yesterday & today, I have run through at least a dozen battery packs or more. I am running an Orion 17.5 VST (Blinky), geared 69/32.
After my 1st battery pack to get gearing & slipper set, I noticed an enormous improvement in acceleration. The slipper did not fade or need to be adjusted/tightened once during the night and it feels awesome from lap one to the end. Jumps that were normally difficult to clear in NT buggy, were soooooo much easier to approach and land clean with on or off power landings.
I switched back to my kit gearbox/slipper for comparisons sake and ran another pack under same track conditions. Lap times were .5 seconds a lap or faster with the Triad and I have already put the Triad back in to stay. It's hard to not sound like some sort of marketing ad, (but in my opinion), it is a real up-grade!
Going to run it more this week and race with it this weekend... Thanks again to K'Dub (Coach), for letting me test it!
Richard
Richard
#2571
Moderator
Trader Rating: 470 (100%+)
How did you get a top shaft already? Thanks for the update. I look foward to running mine.
#2572
So this is an Avid Kyosho part or one modified from another car?
Any testing in mid config?
#2573
#2574
i switched to the aluminum ackerman arm 2 weaks ago the same night i did i got hit in the air and nosed into the lander breaking my plastic bellcranks, so i've purchased the aluminum ones to replace them. it broke right where the ackerman bolts through the bell crank which does appear to be a thin area. imo
#2575
i ordered the rack but havent installed it.. too be honest, if i don't have to i probably wont if i don't break, especially since my servo would be the only weak link in the chain if i went all aluminum.
i'm curious to see what you guys are hitting..
#2576
#2578
actually i dropped my radio going in to practice MM so i haven't had a chance to run it.. a few life events have happened since so i haven't raced in a couple weeks. should have my new radio on fri. and will give it a run this weekend.
have you made any setup changes?
#2580
3 RB6s
their should be three RB6s at the race track this sunday . a guy sent me his RB6 and wanted it changed over to mid motor . he will start with my setup and make changes to suit his driving style if need be . the other guy will be running in rear motor i think running a tebo setup .
