Tekin RS ESC sensored
adjustments for boost within a Boost heading/window in the GUI and like wise for Turbo
That way the guys would know the function/setting is only for boost or turbo and less confusion would prevail.
Key to the software being understood better is a better interface which i believe they are working on.
sounds great.im about to get my 1st rs pro...and i dont know jack about settting there things up.
maybe instead think telemetry or onboard datalogging to determing max rpm in the infield and back straight?
I don't think the X-12 is the best choice for v203, apparently they don't like too much timing advance in the speedo. LRP has told users of the SPX that they shouldn't run the X-12 over profile 6.
I'm guessing the Redline motors or Duo's would still be the better choice to fully exploit the potential of v203
Skiddins
Ditto... as a technology worker I know, the value of a clearly understandable interface can't be overstated. Not to be too critical, however - mad props to Tekin for providing such tuneable electronics at a great price!!
Is this the correct number? A Tekin motor set at the "0" mark is at 15 degrees actual timing? If so, then based on previous setups posted a Ballistic would be set at the leftmost mark which would also be 15. Am I on track with this?
I think Novak's left most is a true 0. They tell you to not run at that. I can't get my Novak to run well at anything less than N.
and I love my tekin and have stuck by it when other speediest
have supose to have been faster but if you stick with it
It will always be there.
Sorry should have stated that I was using 64/29
But I was running
199 as it seemed to run cooler
15 timing after dropping from 20 when new speediest came on
the scene (thanks mikky32)
max turbo
with a .6 delay
have set faster lap times with this setup than most including
the national champ although the consistance is not there yet
watch out Harrison. Rolf
Last edited by Senna Racing; 01-05-2010 at 07:27 AM. Reason: Forgot about gear ratio
