Old 01-05-2010, 12:53 AM   #10036
Damnit Man's Avatar
Send a message via MSN to Damnit Man
Originally Posted by redbones View Post
Pretty easy to tell when they are 5 car lengths behind you and then 5 car lengths ahead of you by the end of the straight.
Nevermind read that wrong.
Donovan P.
Damnit Man is offline   Reply With Quote
Old 01-05-2010, 12:55 AM   #10037
Originally Posted by Damnit Man View Post
Haha not if you can drive with the 203!
yup instantly dropped .5sec with the 203.
redbones is offline   Reply With Quote
Old 01-05-2010, 01:00 AM   #10038
Skitee's Avatar
Originally Posted by marcel p View Post
the advance electronics works way diferent.
its nog working with high rpm.s
The end result is pretty much the same though, so why should one performance enhancing technology be allowed over another.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-05-2010, 01:36 AM   #10039
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by Skitee View Post
So does that mean the black diamond and mamba max pro won't be allowed either ? Just curious since they both do something similar to what 203 does.
Correct. In the 17.5 classes and trans am those are out as well. 13.5, 12th and wgt anything goes.
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 01-05-2010, 01:53 AM   #10040
witz_dan's Avatar
Trader Rating: 25 (100%+)
Originally Posted by 20 SMOKE View Post
any one click user profile and still have internet connected
if your saying when you click on user profile it takes me to the team page then yes. Is that suppose to happen or am i suppose to be able to save a profile?
thanks
witz_dan is offline   Reply With Quote
Old 01-05-2010, 03:15 AM   #10041
razzor's Avatar
Originally Posted by or8ital View Post
Too confusing
Preset profiles would be nice. Flexible is nice and all but it gets damn confusing at times. The delay thing for turbo boost just seems weird. Why not just have a second curve at a different RPM range?
Maybe Randy and the guys at Tekin can take this suggestion for the 203 revision and possibly look at putting the relevant adjustments under there function ie:
adjustments for boost within a Boost heading/window in the GUI and like wise for Turbo
That way the guys would know the function/setting is only for boost or turbo and less confusion would prevail.
Key to the software being understood better is a better interface which i believe they are working on.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-05-2010, 03:21 AM   #10042
morris's Avatar
Trader Rating: 40 (100%+)
sounds great.im about to get my 1st rs pro...and i dont know jack about settting there things up.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-05-2010, 03:59 AM   #10043
avs
avs's Avatar
Originally Posted by HB Moose View Post
Im thinking that the rpm settings should be a factor of Kv but those numbers are unloaded. I think I need to make a load flywheel chassis dyno to test gearing vs timing. This new version just gave us more variables to play with.
maybe instead think telemetry or onboard datalogging to determing max rpm in the infield and back straight?
Tony Shimko
avs is offline   Reply With Quote
Old 01-05-2010, 04:10 AM   #10044
Originally Posted by racer x 1 View Post
what would be the best 13.5 motor for this esc? im hearing the new lrps are the hott ticket.
TEAM CHECKPOINT!!!!!!
Barry Baker is offline   Reply With Quote
Old 01-05-2010, 04:21 AM   #10045
Fred Hubbard's Avatar
TEAM ICON!!!!!! Go to sleep
Fred Hubbard is offline   Reply With Quote
Old 01-05-2010, 05:49 AM   #10046
Skiddins's Avatar
I don't think the X-12 is the best choice for v203, apparently they don't like too much timing advance in the speedo. LRP has told users of the SPX that they shouldn't run the X-12 over profile 6.
I'm guessing the Redline motors or Duo's would still be the better choice to fully exploit the potential of v203
I ran the X12 10.5 indoors with 40 timing and it still came off at 52degC (125degF), never run 13.5 but the 10.5's seem fine provided you calmly experiment with timign etc.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-05-2010, 07:01 AM   #10047
Stogie's Avatar
Ditto... as a technology worker I know, the value of a clearly understandable interface can't be overstated. Not to be too critical, however - mad props to Tekin for providing such tuneable electronics at a great price!!
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 01-05-2010, 07:02 AM   #10048
I think Tekin says "0" timing on their motors is 15 degrees (the sensor is set at 0 but it reads 15 degrees ahead??). Motor to motor translation seems like its difficult.
Is this the correct number? A Tekin motor set at the "0" mark is at 15 degrees actual timing? If so, then based on previous setups posted a Ballistic would be set at the leftmost mark which would also be 15. Am I on track with this?
liquiddog is offline   Reply With Quote
Old 01-05-2010, 07:15 AM   #10049
Trader Rating: 38 (100%+)
I think Novak's left most is a true 0. They tell you to not run at that. I can't get my Novak to run well at anything less than N.
or8ital is offline   Reply With Quote
Old 01-05-2010, 07:18 AM   #10050
Senna Racing's Avatar
Originally Posted by smoke81 View Post
Well it appears for 17.5 v203 won't be allowed at the novak race.. Does anyone have a good place to start for 17.5 duo on v200 on what I would assume is close to a 100ft straightaway.
It has been said before that they will ban this and that
and I love my tekin and have stuck by it when other speediest
have supose to have been faster but if you stick with it
It will always be there.
Sorry should have stated that I was using 64/29
But I was running
199 as it seemed to run cooler
15 timing after dropping from 20 when new speediest came on
the scene (thanks mikky32)
max turbo
with a .6 delay
have set faster lap times with this setup than most including
the national champ although the consistance is not there yet
watch out Harrison. Rolf
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Last edited by Senna Racing; 01-05-2010 at 08:27 AM. Reason: Forgot about gear ratio
Senna Racing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
