xxx4 q.
xxx4 q.
Hi, i just bought a xxx4 from a buddy and he did not have the manual, what is the suggested pinion for a 12 turn motor with a 90t spur?.
Thanks.
Thanks.
Id run a 20 pinion. if its too hot ( which its bound to be, I don't think ive even had a cool motor after a 4whl run) drop a tooth and keep going until its at a nice temp.
thanks im running a D5 12x1, and the kid had a 124 tooth spur in it with like a 22 tooth pinion, i knew i needed to change that right away, and do they make a motor heatsink that will fit under the xxx4 body?
Thanks.
Thanks.
and is a xxx-s spur gear the same as the xxx-4? if not it has a blue spur gear in it does anyone know what tooth that is?, thanks.
Thanks.
Thanks.
thanks
If you want the manual you can download it from:
http://www.teamlosi.com/Products/Sup...rodID=LOSA0015
