Old 04-19-2005, 04:01 PM   #1
RPC
RPC's Avatar
Default xxx4 q.
Hi, i just bought a xxx4 from a buddy and he did not have the manual, what is the suggested pinion for a 12 turn motor with a 90t spur?.
Thanks.
RPC is offline   Reply With Quote
Old 04-19-2005, 04:12 PM   #2
Nick111's Avatar
Send a message via AIM to Nick111
Id run a 20 pinion. if its too hot ( which its bound to be, I don't think ive even had a cool motor after a 4whl run) drop a tooth and keep going until its at a nice temp.
www.BIGjohnsonpaints.webs.com
Nick111 is offline   Reply With Quote
Old 04-19-2005, 04:31 PM   #3
Trader Rating: 17 (100%+)
With a 10x1 D6 (timing close to 20 degrees, Putnam X brushes and purple springs) run a 92 spur with an 17/18 pinion. I would do the 18 tooth pinion.
429racer is offline   Reply With Quote
Old 04-19-2005, 04:38 PM   #4
RPC
RPC's Avatar
thanks im running a D5 12x1, and the kid had a 124 tooth spur in it with like a 22 tooth pinion, i knew i needed to change that right away, and do they make a motor heatsink that will fit under the xxx4 body?
Thanks.
Old 04-19-2005, 04:48 PM   #5
RPC
RPC's Avatar
and is a xxx-s spur gear the same as the xxx-4? if not it has a blue spur gear in it does anyone know what tooth that is?, thanks.
Old 04-19-2005, 06:20 PM   #6
Nope, they are different. The XXXS uses the spur gear and the drive pulley molded together (unless you get aftermarket gear adapters) and the XXX4 uses a spur gear with a slipperhub and drive pulley attaching to it. If it is a 64 pitch it would be a 128 tooth or if it is a 48 pitch it would be a 92 tooth spur.
Old 04-19-2005, 06:22 PM   #7
Thanks.
As far as a heatsink goes, it isn't really necessary because of the lack of air flow. I think you could use the MF heatsink though if you wanted to use one. It covers up a small portion of the motor and you could probably clear the body.
Old 04-19-2005, 06:23 PM   #8
RPC
RPC's Avatar
thanks
Old 04-20-2005, 02:33 AM   #9
If you want the manual you can download it from:
http://www.teamlosi.com/Products/Sup...rodID=LOSA0015
colinradford is offline   Reply With Quote
Losi XXX4 roller and XXX4 NIB Billy-Ho R/C Items: For Sale/Trade 11 11-28-2007 04:44 PM
wtb xxx4 thekid22 R/C Items: For Sale/Trade 2 01-04-2007 09:54 PM
XXX4 almost G+ jasong R/C Items: For Sale/Trade 5 11-05-2005 06:35 PM
BMI Tc3 and xxx4 g+ fs! Kave R/C Items: For Sale/Trade 2 08-14-2004 11:17 AM
Xxx4 G+ craig14xxx R/C Items: For Sale/Trade 4 07-07-2004 02:54 PM
