XXX4G+ Rear End Fix >
XXX4G+ Rear End Fix
XXX4G+ Rear End Fix
Old 04-19-2005, 09:34 AM
Driver1's Avatar
Default XXX4G+ Rear End Fix
BK2 rear end w/ MF2 rear hubs...
on high bite...AMAZING
with cavaleries minreg setup only switch to silver front springs..
and run short rear arms...
and BK bones up front...
braaaaaa
Driver1 is offline
Old 04-19-2005, 10:24 AM
cartmen34's Avatar
where did you place the camber link? Caliveri's setup position, or did you take advatage of the 3rd outer location on the MF2 hubs?
Also, you mention BK bones up front. Do you mean the older style universals that came on the xx-4/xx-4we? I didn't think they made bkbones for the front of the 4wd.
Do these have the same effect as bones vs CVD's in the back? (less side bite with CVDs)
cartmen34 is offline
Old 04-20-2005, 04:15 AM
Doughty's Avatar
the BK bones mensioned in Ryans setup from the worlds are/were a prototype.
Don't quote me on this but I seem to remember them being a CVD still bit they used bearing rollers at the bone/outdrive end.
Its been nearly 2 years since I seen these so I could be wrong
in the UK we have been running the BK2 rear wishbones/Trinity BK2 rear hubs since the BK2 came out.
works very well
EDIT - just noticed you used the short rear arms with the BK2 rear end...? what is the point, that is the same as standard
Doughty is offline
Old 04-20-2005, 06:30 AM
Dustinkeys's Avatar
I think he used steering rack bearings for the bk bones.
Dustinkeys is offline
Old 04-20-2005, 10:02 AM
Driver1's Avatar
EDIT - just noticed you used the short rear arms with the BK2 rear end...? what is the point, that is the same as standard [/B][/QUOTE]
so that i can run the mf2 hubs...
inside hole..
im running the older style xx-4 type bones...
with prototype white derlin bones...
cant break em....
Driver1 is offline
