Capricorn LAB-C01
#1937
Which saves the most weight and stronger
Ergal ball pivot. Or titanium?
#1939
what is the weight difference for the Kevlar and the normal front and rear diff housings?
#1940
Weight differance is a few gramms. But a thing to consider is what i have experienced. Titanium breaks and aluminium bends. The CAP alu pivot balls are hollow but the xray one`s are not. So they are stronger and only bend with shunts. so it will get you to the finish with maybe handling difficulty.
#1941
Best wishes; Jens
#1942
does the suspension bushing that gives 0 setting at suspension come with cap-14038?i see at photos that it has all the other settings (1,5-1-0,5) but not the 0 setting.
#1944
Trader Rating: 13 (100%+)
We have, and it is great. Less agressive than the SRS-N, and not totally unlike the P37 on the track that we tested at in our opion. You should give it try; it's always an alternative. The SRS-N is usually our preferred choice however, as the boy likes the aggressive steering that it gives.
Kindest regards,
Lars.
Kindest regards,
Lars.
#1945
It'a said that is similar with P37.
#1946
I hope it works because I think it's pretty nice looking shell:
Btw, for the ones who've been searching for some of those extra body supports on the rear of the shocktower, the ones Serpent makes are a direct fit:
You only have to cut a tiny amount of the locating pin on the bodypost.
http://www.capricornrc.nl/Webwinkel-...s-(2-pcs).html
#1949
