Team Orion Revolution motor
I just bought a Steenari Pro 12x2. After about half throttle, servo and motor both begin to jump around, very badly. This is the speed controller I have:
http://www.teamtekin.com/Manuals/TEMFET_ESC_1988.pdf
The instructions say it can handle 240a continuous. The same speed controller used to be in a sprint car with a motor that drew atleast the same power as the motor I have now.
I have 2 of these speed controllers, both exhibit the same problem. I don't have a third speed controller of a different make to test. When I put a different motor in, an old worn out 12x1 or an old Peak stock motor, I have no problems (other than the car is slow, lol).
The only answer I can come up with is I need capacitors on the motor, but these v2 motors aren't supposed to need them according to everyone I talk to.
Any suggestion would be immensely appreciated!
Thanks!
Thanks!
Most likely there is a problem with your speed control. You can send the motor toTTeam Orion customer service and we can take a look at it.
or call Customer Service at 714-694-2812.
Thanks,
Gary
Thanks,
Gary
Three strikes & you're out Orion!
Definitely sounds like a 'noisy' motor causing your glitch.
As long as the red led is on, the capacitors are working. Also, check your wiring and make sure nothing is grounding out of the chassis.
I don't think I could wire 3 speed controllers and 2 different motors, and have them work, and then switch to a third motor and have it not work. There is only positive and negative on a motor, its quite simple actually.
I've sent the motor off already anyways.
Please send in the motor and I will take care of it for you.
Team Orion
Attn:Joe Pillars
22601 La Palma Ave #103
Yorba Linda, CA. 92887
Thank You,
Joe Pillars
Team Orion Customer Service
Team Orion
Attn:Joe Pillars
Thank You,
Joe Pillars
Either way I will receive your motor.
