Old 03-06-2005, 11:31 AM   #1
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Default Team Orion Revolution motor
I just bought a Steenari Pro 12x2. After about half throttle, servo and motor both begin to jump around, very badly. This is the speed controller I have:
http://www.teamtekin.com/Manuals/TEMFET_ESC_1988.pdf
The instructions say it can handle 240a continuous. The same speed controller used to be in a sprint car with a motor that drew atleast the same power as the motor I have now.
I have 2 of these speed controllers, both exhibit the same problem. I don't have a third speed controller of a different make to test. When I put a different motor in, an old worn out 12x1 or an old Peak stock motor, I have no problems (other than the car is slow, lol).
The only answer I can come up with is I need capacitors on the motor, but these v2 motors aren't supposed to need them according to everyone I talk to.
Any suggestion would be immensely appreciated!
Thanks!
HVAC25000 is offline   Reply With Quote
Old 03-06-2005, 12:06 PM   #2
Gary Guest's Avatar
Send a message via AIM to Gary Guest
Most likely there is a problem with your speed control. You can send the motor toTTeam Orion customer service and we can take a look at it.
or call Customer Service at 714-694-2812.
Thanks,
Gary
Gary Guest is offline   Reply With Quote
Old 03-06-2005, 12:08 PM   #3
HVAC25000's Avatar
If I haven't gotten it figured out in a couple days, I'll do that.
Old 03-06-2005, 01:27 PM   #4
HVAC25000's Avatar
I just tried it with a brand new (as in never been used except once to insure it worked properly) Novak T4, rated at 176amps, and experienced the exact same problem. I'm highly doubting I have 3 speed controllers malfunctioning the exact same way.
Old 03-06-2005, 05:58 PM   #5
ScottyP's Avatar
Three strikes & you're out Orion!
Definitely sounds like a 'noisy' motor causing your glitch.
ScottyP is offline   Reply With Quote
Old 03-07-2005, 07:08 AM   #6
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
thats along the lines of what I am thinking. solder on some caps and see what happens then.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 03-07-2005, 11:25 AM   #7
Joe Pillars's Avatar
As long as the red led is on, the capacitors are working. Also, check your wiring and make sure nothing is grounding out of the chassis.
Kyosho America, Team Orion, Peak Racing, AKA, KO Propo, DiBrino Designs, JTP, RCE, Rockstar Energy Drink, www.thebigrc.com, Portland R/C Raceway (www.prcr1.blogspot.com)
Joe Pillars is offline   Reply With Quote
Old 03-07-2005, 01:24 PM   #8
Brian Miskolczi's Avatar
Trader Rating: 156 (100%+)
Ya if your having problems its either the motor is screwed up, or its more than likely user error, if you can take a pic of the way you have it wired up that may help.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 03-07-2005, 02:35 PM   #9
HVAC25000's Avatar
I don't think I could wire 3 speed controllers and 2 different motors, and have them work, and then switch to a third motor and have it not work. There is only positive and negative on a motor, its quite simple actually.
I've sent the motor off already anyways.
Old 03-07-2005, 02:49 PM   #10
Please send in the motor and I will take care of it for you.
Team Orion
Attn:Joe Pillars
22601 La Palma Ave #103
Yorba Linda, CA. 92887
Thank You,
Joe Pillars
Team Orion Customer Service
Old 03-07-2005, 03:36 PM   #11
HVAC25000's Avatar
Who did you think I sent it to? lol
Old 03-07-2005, 03:48 PM   #12
Either way I will receive your motor.
Team Orion Revolution Modified Motor 8x2 - $25 shipped JKA R/C Items: For Sale/Trade 3 05-18-2006 05:21 AM
Team Orion Revolution 10x2 Modified Motor $30 shipped JKA R/C Items: For Sale/Trade 2 05-17-2006 04:06 PM
F/S Team Orion Revolution Motor dragracer72nova R/C Items: For Sale/Trade 0 07-21-2005 02:36 PM
Team Orion Revolution motor HVAC25000 Electric On-Road 18 03-07-2005 05:08 AM
Team Orion Revolution Motor Gezuz Electric On-Road 5 08-21-2003 04:01 PM
