Old 03-07-2005, 08:03 PM   #1
macnkitty2002's Avatar
Exclamation Question about Novak Spy in a Mini-T
couldn't find a mini-t thread to put this in so here goes:
I just got a novak spy for my mini-t. I was using it and i dont like how it automatically goes into reverse when i want to brake. i know you can disable the reverse feature on the unit, but can you have reverse and brake?? do you think that i have to disable reverse in order to produce a braking action?
thanks
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-07-2005, 08:59 PM   #2
try reprogramming the esc. i am running a spy in my m18 and it has brakes. what might be happening is if you lock up the rear wheels in the dirt the esc thinks the truck has stopped and its going into reverse. the XRS uses a double pump feature to go into reverse. try your mini t on the pavement without skidding the rear tires and see if it still goes into reverse. you will be able to see if it has brakes.
baih is offline   Reply With Quote
Old 03-08-2005, 02:58 PM   #3
beetlebz's Avatar
Send a message via AIM to beetlebz
i hate the brakes on both speed controls. ive given up and gone to forward only controls. they are both speed sensitive reverse. the XRS is supposedly double pump, but if you arent going forward fast enough it will instantly kick into reverse. its brutal!
beetlebz is offline   Reply With Quote
Old 03-08-2005, 05:01 PM   #4
i dont have an XRS though, i have a Spy micro. i mainly run on pavement, and when i am off throttle and the truck is coasting to a stop, i press the trigger forward while the truck still has momentum. the rear wheels immediately kick into reverse and spin backwards slightly while the truck is still going forward. i know this is probably killing my transmission. so do you think if i change to forward only(hardly use it anyways), i will brake instead of going into reverse(it cant b/c its disabled)?
Losi Rock Rey
Old 03-08-2005, 05:34 PM   #5
Charlie's Avatar
The Reverse can be Disabled on the Spy, and the Brakes will still work normally.
Sometimes the Smart Braking gets tricked by the motors, Some of the motors don't create enough signal for the Smart Braking to see, so the reverse will kick in early.
Or something is wrong with the ESC and it's not working like its supposed to.
Email me if you like.
Charlie
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 03-08-2005, 06:46 PM   #6
i will try disabling the reverse and see what happens.
Losi Rock Rey
Question on the Mini-Z's THE DOCTOR Micro and Mini Scales 2 11-16-2007 10:50 AM
mini question?? HNH Micro and Mini Scales 16 03-13-2007 05:07 PM
mini z question? baxter007 Micro and Mini Scales 28 12-04-2006 01:51 PM
mini-z question RCNitroDude999 Electric On-Road 3 03-12-2005 05:47 PM
Trade: Mini T w/hop ups or 2 Novak ESC's for Novak SS5800 system jeemann99 R/C Items: For Sale/Trade 1 01-10-2005 09:20 AM
