Schumacher Corner
#7981
Originally posted by STLNLST
another reason for the chit chatter is because the car is working pretty good so not too many people are asking the usual questions. A basic set up works just about everywhere. What type of surface are you running on? We are now into our carpet season so most of our testing out in the Sacramento area will be all rug until March/April.
#7982
Originally posted by Matt Howard
so stlnstl, what are you doing tonight? Did you watch the pistons game today? They look good this year. Are you gonna run 1/12 at the regionals? chit-chat with you later LOL People need to take it easy here, it's all good Go Yokomo!
#7983
There is a a reason Shane set up reginal threads on here. Chit chat is one thing but to carry on conversations in a thread that it is not meant for is inconsiderate.
#7985
Maybe you could direct these people to your local threads and help promote your area tracks and help out the newbies at the same time. I hope what I said wasnt taken as sarchasm.
#7990
What should I look for with a new car. Hop ups? Fixes? Any weak parts needing attention? Going to be running an Mi2 on carpet with foams. Thanks
#7991
The only hop-ups I would say are needed are the lowered shock towers and steel or Ti cvd's. The only parts I've broke are the front arms and caster blocks. Another really good hop-up is the alloy rear hubs. They make the car more adjustable and give more steering by freeing up the rear end a little.
#7992
I've taken some big hits, and so far all I've broke is a caster block, havent bent any hinge pins, or cracked any other pieces.. I like the alum spindles because it makes it easy to ensure the kingpin angle is straight and not off any when threading into the stock spindles.. Otherwise, like mo said, towers and some cvd's... should be all ya need
#7994
alloy rear hub Qs
I just purchased the alloy rear hubs and also the inboard mounts.
I have a few questions:
1) It looks like you can have inboard toe and outboard toe. What is the difference?
2) With the alloy rear mounts, it looks like you set wheel base by positioning the the plastic insert and using the set screw. Problem is, its impossible to find the exact same position each time. Maybe its something I am doing wrong. I am unclear to how this adjustment is suppose to work.
3) Is the point about adding a spacer under the ball joint on the top a way of tuning roll center? Adding more spacers lowers roll center? Is that right?
The paper instruction that comes with the rear hub is unclear.
4) One last question, which belt tensioner can I remove to loosen up the belt? I will be running Stock and 19T if it matters
Some help will be greatly appreciated
#7995
